mopartechnician
Everything posted by mopartechnician
  1. Airdogs and raptors mount in the same place on the frame. Raptor frrp mount in stock location
  2. Fuel pressure and any codes will help too
  3. Ive installed two airdogs and a raptor recently and so far so good, also had two raptors warrantied with no problems at all. From what I have seen, they all have been having problems. Buy a fuel pressure gauge ASAP
  4. http://youtu.be/piyJ6FahRb4 Here is my old 02 doing 3 cylinder idle. Its will scare the s$&t out of you the first time it kicks in
  5. Whats it cost to get rebuilt? I got one hanging in the garage that is worthless since quad went under
  6. Obviously you have never been to nebraska. Its 28 right now and 18 tomorrow night. It rained last night and froze. I scraped ice this morning and did exactly what i said about starting and driving it.
  7. The best way to warm up your truck is to drive it. Idleing does nothing for your engine but wear out quicker, burn fuel, and you take a chance at varnishing the valves. I only idle long enough to build oil preasure and drive it
  8. All you would have to do is tap a power wire into the relays to kick them on with a switch. But running the heaters isnt going to hel that is why the computer turns them on when needed. You are just going to make the batteries and alternator work harder to make up
  9. Don't know how to help ya, but I do work on big choo choos. 2 stroke EMDs and 4 stroke GEs
  10. Ya, quadzilla is the only one I have heard do this, and it is a horrible design. I had a buddy that fried the motherboard three times on his adrenaline
  11. How warm? What is the condition of the coolant? Is your radiator plugged with oil? Does the fan spin freely when the engine is cool and off? What kind of mods do you have done?
  12. http://pureflowairdog.com/raptor.php
  13. That is the frrp or whatever they call it
  14. Im putting ball joints in a 01 and it does not have sensors on the front hubs. This is the first truck ever that i have done with no front speed sensors
  15. The raptor is pretty much the same kit as an airdog. It mounts back by the tank with the same brackets as an airdog and has all the wiring land hoses needed. It is plug and play. It will hook into the back of filter housing so you will need to get a big line kit from the filter housing to the vp44. The only difference between a raptor and aidog is the airdog has a filter and water seperator. If you want extra protection for your raptor. Get a inline fuel filter that is like 120 microns. Just ask your parts store for one that goes into 1/"2 hose and mount it between the pump and the tankYes, relocating the lift pump back to the frame makes a huge difference. Like i said before the heat and vibration from the engine takes out the lift pumps. Also it is easier to push the fuel than to pull it.
  16. Call Goerend Transmission they are amazing parts.
  17. Buy either an air dog or a raptor, I don't like using/mounting the lift pumps on the motor, too much vibration and heat. When I install airdogs/raptors on short bed trucks, I just mount the pump on the outside of the frame rail.
  18. That's probably why it isn't working, if you do that, it fries the chip
  19. Did you jump start your truck or somebody elses truck with the quad hooked up?
  20. I would call Erick as browns diesel. http://brownsdiesel.com/ Him and his brother are amazing and know a lot about transmissions. Tell them I sent ya.
  21. Well technically you aren't suppose to go under 10 but anything under 14 isn't lubricating and cooling the pump. So a 15psi light would actually be an indicator that something is wrong. How can you run with poor pressure, just depends on the situation, as long as you are not hard on it and replace it as soon as possible than you shouldn't have any problems.
  22. I have run two sets of jammers in two different trucks with no problems, just fyi, and actually have them in my current truck
  23. No need to pull fuel filter housing.
  24. I have seen and heard nothing but problems with all jasper products. Im not very good with autos but i would suspect tq. - - - Updated - - - How far are you from riverdale, CA?
  25. Did you replace connector tube o-rings? Those are well known for causing hard starts when cold. Even if you replaced them and nicked one on install it will do the same
