Everything posted by mopartechnician
AFE Bladerunner turbo ?
I am a big hater of ats. Too many horror stories of their products not doing what they advertise. Like i said call erick and he will tell you what works with your setup and your goals
Airdog quality
Actually the airdog is now a different design. I havnt had a chance to test one yet. Im not a real big fan of fass either. At this point I think a mechanical pump is the best. I also have a fuelab on a pickup and so far havnt had any problem with it even in the cold.
Call erick at browns diesel 559-867-1111. Tell him seth sent ya and he will hook you up with the right turbo
12 Fuel psi idle 0 wot - Help
Randy is who I ordered it through. I will see how this winter holds up
I used amalgamated last year and it didnt help me. But I think my biggest issue was my airdog gelling up. My dad has been using it for 5 years and hasnt gelled up. About a dozen people I know bought some with me last time I ordered, and only had a couple gel up. My buddy used it once and he gelled. Ever since then he has used stanadyne and hasnt gelled. So its really hit and miss
gauge kit
Do not buy glowshift. You get what you pay for which is junk. I have installed three sets of them and almost every gauge has been warrantied at least once. Spend the extra money and get isspros
Airdog filter changing tips
Inline with hose and any home improvement store will have then. I also pulled the handles so nobody could reach down and turn them off
I put ball valves on both sides of the pump so I could shut them off. I dont like using vise grips but I have used them but surrounded the hose with a rag or a small piece of cardboard
AirDog 150 in cold weather
Why should they have to pay for it? Thats just like saying dodge should have to pay for a trans or an engine because you thought 200hp over stock was needed.
Dealer says high idle won't work because of remote starter/alarm
I keep telling people its super simple to enable it and that you dont flash the computer but nobody believes me
Transfer Case not allowing N or 4L
Its just easier to pull the t-case. And they are super simple to tear apart.
The throttle is true. On my 02 my apps was going bad because I could see my throttle position on my adrenaline monitor, and every once in awhile would show 1% and my high idle wouldnt work
Its not airdogs fault. Fass does the same thing. They actually have a kit with a small heater.
On the 3rd gens they dont work unless you ground out a wire
The problem is the coolant wont help until the the engine warms up. You need to do something while the pickup is sitting. Thats why I say heat tape wrapped around the filter and lines with foam insulation around the lines. Also something like an emergeny blanket wrapped around the pump and filters
Im an idiot. It worked on my 02 6speed. Man im forgetting too much stuff
Wont work on a manual transmission
Va
abs and brake light
99% of the time its the rear wheel speed sensor. I have only seen one or two front wheel speed sensors go bsd and when they do its usually caused by a bad hub. I would get codes pulled to see what is actually wrong
Torque App for 24v Cummins custom PID's
I use the torque app all the time on multiple vehicles. Im not smart enough to do the pids
Hard starts and weird tach
Did any of those shut off when this happened?
How much stuff do you have on your key ring? To me it sounds like an ignition issue. Did you have the fan running or radio on? Or could be a connector issue
Over treating doesnt help
It counts rotations for your vehicle speed (mph) not engine speed (rpms)
A rear wheel speed sensor has nothing to do with the tach
