mopar440cu
Everything posted by mopar440cu
  1. Well I went with the Westin Pro Traxx 6" black oval. I really didnt find one I liked that was full length/wheel to wheel and I didn't want an electric one do to where I live in the country. I appreciate everyone advise!!
  2. Anyone have any recommendations for a full length black nerf/side bars that will fit this new 2019 tradesmen duallie? Its been awhile since I bought some and cant find the ones that i have on my other 3500 Dodges that have them. LOL Thanks for any info or advise!! Steve
  3. The wife called them and they told her it is only one tie rod end that was in the recall. I don’t know which one, as I didn’t call them.
  4. Working fine. Trying to fine tune with the Quadzilla.
  5. I also reused my pitman arm and I have a few 01 3500’s 4x4’s that are converted with no problems.
  6. Will someone please explain why the 320 pop instead of a higher pop off number, like per say for example 400 on the injectors. If I remember the lower the PSI pop the worse atomization is and it doesn't burn the fuel efficiently. which leads to poor performance and mileage. So if I am guessing the higher the numbers in bar the more advanced the timing is?? Thanks!
  7. Very nice! Did you change the injectors? I thought you had smaller ones before,. Either way its great being near 500 HP!
  8. They are headlight led’s. I just have them on a shelf in the barn. The trooper had an attitude and even went into saying my stack was illegal, etc etc.
  9. I had 8000k led on one of my 3500's, got pulled over by a trooper, told they were illegal and gave me a warning. I didn't argue with him and just took them out because they were blinding on coming traffic no matter the angle I set them at. We sometimes pull over the legal rate so, I don't need the attention it was already getting. Lol That being said they were awesome though. I would use them again on a offroad truck!
  10. How would he increase the engine operating rpm range?
  11. I did read all the posts, but was getting a bit confused on whether or not a person should replace or add the 2/0 cable is why I asked. It doesn't take much to confuse me when it comes to electrical stuff! LOL Reading it I did notice @W-T had extra accessories, but still wondered if it was necessary or worth doing and IBMobiles list did not include the 2/0 cable either, thus another reason for asking. Trying to get my ducks in a row.
  12. Can someone please explain what the High Idle Delay Setting is used for on the Quad and Warm Up Mode Setting. I am guessing the High Idle is used possibly to help volts for accessories?? I am also guessing the Warm Up Mode lets the truck warm up if its cold outside, but does this mean if I set it to say 195 degrees the truck can not be moved until it reaches this temp? Trying to still figure this out. Thanks for any help getting me to understand this!
  13. Question, Did all you use 4 new positive and negative wires going to the main battery then to the auxillary battery using #2 gauge? Or did you just keep the original positive wire and do the rest of the mods? Thanks!
  14. I got my new Autometer "A" pillar triple gauge mount today with gauges and was wondering how you guys got the wiring and tubing through the dash? I am guessing drilled a hole somewhere to manipulate the wires and such through? I am going to try to install the Trans. Temp, Boost and Oil Pressure this weekend hopefully, if things go right. Thanks for help! Steve
  15. What is the uses of the high idle switch other than when it is cold outside? Thanks for the info!!
  16. Yes, that part is broke. Probably melted the parts together. Lol
  17. This was taken at 5:20pm in my pasture today and its not even the hottest month yet here! Lol I had to turn on the sprinklers for the cows to cool off before they melted. Lol
  18. Just had to add this lol!!
  19. It gets that hot trust me, but not everyday. I/ we work in it everyday and pray for sun showers and clouds everyday! Actually thinking It’s not the sun so much we hate, it’s the high humidity that kills us working outside, but it’s a paycheck! Lol My other half agreed and said it can get hot out in California also, she lived there, but like you stated the humidity between the two states makes a big difference. I have another friend from Florida who now lives and works outside in Nevada and complains his state is the hottest also, but admits it’s a dryer humidity that you can deal with. This humidity here is a pita plain and simple. I guess we can’t have our cake and eat it also as they say. Lol
  20. It’s like I said hotter than the gate hinges from Hell here in Florida! Lol 110degrees high humidity in the shade.
  21. I had a Redhead and it didn't last long.
  22. For all my trucks and cars in Florida I use They are great for us living near the hinges of Hell! LOL
