Heavyd1980
Everything posted by Heavyd1980
  1. is the 3rd gen a direct bolt in?
  2. Ummm just nuts and bolts huh?? and some cutting, welding, reshaping, and covering!
  3. damn it that sucks!:banghead:
  4. does the truck still move? Sounds kinda like maybe a input shaft???
  5. JL did you get your engine yet and does it come with a cam?
  6. Congrats man!!! Glad to hear!:hyper:
  7. i guess thats a possiblity but i found when my fuel pressure was doing funky crap like that it was water hammer. do you have a fuel snubber or needle valve installed?
  8. Now there is a good member!!! STdog your bad@$$ man:thumb1:
  9. the dealership unless you have a smarty or access to a smart, I believe the quadzilla adrelaine has this feature as well:thumb1:
  10. yes that little puppy is in there if its hasnt been changed in a while!
  11. wow that is awesome! can you would you be up to making some more of those?
  12. i would recommend that you wait and have them installed you will run thru tires and not like the way it drives if you dont! Trust me I have been there and done that!!!:banghead:
  13. im always up for cheaper!!!
  14. Mine i would be all over that with a little work you should have a pretty sweet and cheap pickup!!!
  15. well i guess we will see if the new shift tower helps out then!
  16. Welcome to the site and from all of us in the midwest!!!
  17. i have the factory posi in my truck and it doesnt act up at all unless the ground is wet!
  18. i would go with the offset bushings to make sure you have plenty of room to get it adjusted properly.
  19. well i guess i will revise my oil change mileage and go for 5k since i do quite a bit of stop and go driving.
  20. 3.36 here in southeast kansas!:banghead: not quite as bad as you Mopar but still pretty dang high
  21. my truck has offset bushings in it and the alignment shop didn't know whether they were going to need them or not until it got on the alignment rack and then i needed a track bar as well.
  22. i was kinda wondering that myself
