dripley
Retired Staff
Everything posted by dripley
  1. I have been thinking about the same thing. I have some aluminum step tread, thought l would put a 15* or so bend in it and use some u bolts and spacers to hold it there along the tranny. Guess I better get some leather, I thought you just used it on the upholstery. No wonder my seats feel strange.
  2. The port I used can be used for a mechanical oil pressure gauge so it would be under pressure. Maybe your vacuum pump needs to be resealed or your oil pan is leaking. The way the air blows around under there its not always easy to see where its comi g from. FYI, it's the ECM on the block, PCM is on the firewall.
  3. Looking real good. Maybe I will see it while driving thru on 81. I go thru there twice a week to and from work.
  4. I have been looking. Actually found one a while back, a 2nd gen 1500. The clear coat was gone but the body was straight. It was mechanically sound and nothing was leaking any where under the truck. Got the guy down to $2k and asked if he had the title. No problem all we got to do is sign it over. Went to a notary to do that and as we are standing in line I get a look at the title and I notice the first name on it is Doris. Well he did not look like a Doris to me and needless to say the title was not in his name. Dont have a clue as to what he was thinking about how to get it in my name and the notary just laughed at him.
  5. Mine needs some rejuvenation if I could find the time. Is your cruise fly by wire or vacuum controled?
  6. The 1693 is just telling you there is code stored in one of the computers and is not needed for diagnosis. The other 2 are no bus messages which is a little over my head. You can look them up in the articles section here. I am having a hard linking them but they are in the articles section, 2nd gen, engine, then OBDII error codes.
  7. I connected an oil pressure switch in that general location a long time. It was a threaded hole with a plug in it. But as I remember the hole was horizontal and not vertical like shown in the picture. It does look like something was installed there at one time. Is that your engine in the picture? I would also think that if it Is the same as I used it leak like a flood since the hole was under pressure.
  8. Me being on the road all the time is my biggest enemy. I need to give my truck some attention that takes more than day or get a spare truck.
  9. Most definitely will. Had the Timbo on mine long before the Banks EB.
  10. Good to hear you found the issue. I think we like to call it thread enhancement rather than jacking. A lot of natural curiosity around here. No offense meant nor taken. Now to
  11. First off welcome to the forum. Second, is your truck bone stock? Third, any trouble codes? If you dont have an obdIi scanner most auto parts places have them to loan. The codes are going to help point us in the right direction.
  12. They should unless you turn the passenger side off.
  13. Some days are better than others.
  14. That's what I thought. Missunderstood what you said previously.
  15. So the picture is of the nozzle after running the Pennzoil or the Supertech?
  16. My truck likes the bio diesel blends. I know alot of you don't trust it but my trucks runs and performs on it well. I have been using for 4+ years with no problems. I just wish they would label the pumps better so you knew what you are getting. The pumps on my trips to Maryland state 5% to 20%. 5% and below dosn't require any label.
  17. Nothing like peace of mind. I changed my last one for the same reason but it had seen a lot of low fuel pressure and a failed lift pump.
  18. Mine was stuck on for a long time. Put the new.to me seats in and it went off. I believe the air bags will go off no matter what unless you turn off the passanger side switch then it want go off.
  19. @Shmokes24v what is that in the picture?
  20. Gorilla tape, the wide roll.
  21. First I would ditch the power service and start using 2 cycle oil, TCW3. Wal Mart super tech is readily available and reasonably priced. Here is some info. I would also agree with the above. If it is not giving you any trouble or codes i dont think I would replace it. Just getting one for spare might be troublesome since a core deposit is required, usually with a time limit on the return or the vendor will keep your core deposit. @Mopar1973Man's last pump had 243k or so miles on it when it went, mine has 220k on it and still running. Both were remans and not the oe and both have seen 2 cycle their entire lives. My oe and Mike's had right 75k on them when they died. The power service does the opposite o 2 cycle.
  22. I can identify with that. If I have an idea its coming I will park nose down hill. I have starting in reverse once or twice but got to have some speed for that. No speed and the clutch might as well be a brake pedal. If you had done that look at all the cultural differences we would have missed out on.
