dripley
Retired Staff
Everything posted by dripley
  1. Thanks @BBHD, that would clear up the confusion. Mine was like your uncle's.
  2. I have heard that the synthetic is not as good as the dino. I would have to defer to someone that knows better than me for the why. As for me the dino is cheaper and easy to get and for the most part I am a dino guy anyway.
  3. The only picture I did not get was the last one. All the others a pretty much what I dealt with when replacing my in tank pump with the AD. I never had to deal with a connector like you show in the last picture. My in tank pump was connected to a power source to the relay, the oe harness for the lift pump connected to the relay also for the trigger and then a harness from the relay to the AD to supply power for it. I do see two wire looms in the pic. One seems to have on wire going to the connector and it looks factory. There is another that runs off perpendicular to the connector. I will have to take your word on them being connected. I dealt with nothing like that on mine.
  4. I dont remember mine going to any other factory connector other than the lift pump harness. How is it connected into that plug? Every thing in that connector looks old. The only new wires are at the top of the picture and I assume they are for the FASS,
  5. The fuel tank needs no vacuum. Sometimes the vent will clog and cause vacuum as the fuel is pulled out causing issues. You dont want vacuum in the tank.
  6. How is your pressure drop at WOT. Thats the other important number. You are trying for 14# or higher. As far as the 2 stroke, nothing fancy needed there. Ash less is the key. Many of us run the Super Tech TCW-3 from Wal mart. It fits the bill just fine.
  7. Do you have a snubber or something like it to protect the sender?
  8. Nope. Only when it is muddy. While some of my job sites can get very dusty I am not working the truck once I get there. Most sites for a CFA are only an acre and there is no need to drive around it. Now the Love's I just built was on 24 acres I did drive around it quite a bit. I dont seem to have suffered any ill consequences from the K&N other than an oily turbo. I only cleaned 3 maybe 4 times the whole time I had it. When I cleaned it I just used a pan full of cleaner and rinsed it with a garden hose without a nozzle on it. The media is pretty delicate. My wifes 1st Dakota came with one. She got on oil change on the road once and the place did her a favor and cleaned it. They washed it and then used compressed air to dry it. That was the last one she ever had. The filter media does not stand up to compressed air. Dont get me wrong I will never run one again, but dont really have any regrets. Only time will tell.
  9. I thought we were trying to disconnect the fass to see if you were over pressuring the pump. Sorry about that. My old in tank harness is hanging on a wall in my shop. It came out when I ditched the in tank pump. There is nothing it is needed for anymore. IIRC it is very similar to my AD harness, functioned the same any way anyway. Any way after the AD install the harness does nothing, it has nothing to control anymore. Once I disconnected it from the pump and the oe harness the only other wire I remember was for power. I dont remember where it was connected, I just took it loose.
  10. If you disconnect the oe harness that ran the oe carter pump from the fass harness the pump will not run. Unless the fass system does not use the oe harness for a relay trigger. Without the trigger the relay will not engage power to the pump. My AD harness has a fuse in it and I am assuming the fass harness has one also. Pull the fuse and the pump will not run. This would be the easiest way on my truck. You can do either one and the pump will not run. There is no need to cut or disconnect the power supply.
  11. Just pull the fuse in the Fass harness or unplug the the lead from the ECM. Either one will shut the pump down. When I removed my in tank pump I pulled the old harness that connected it to the ECM. Your old one should not be connected to anything anymore.
  12. I dont think so. A broken vacuum fitting or line in the vacuum system will cause the above. Might not be obvious either.
  13. I would have thought the hard part was figuring out the power steering vent cap was causing the brake lights to stay on.
  14. Well they got them from $62 apiece to $365 also if that interest you. http://www.rockauto.com/en/catalog/dodge,1999,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1377569,brake/wheel+hub,wheel+bearing+&+hub+assembly,1636
  15. Thats one for the memory banks there. Glad you found the problem. You need to get that in a trouble shooting guide somewhere.
  16. Nice ride and good find. Heated and chilled cup holders, now that is fancy.
  17. I think I would rather pull a 20 year old oe hub bearing as chase electrical gremlins. That or just put my hand on an anvil and hit with BFH.
  18. That sucks. FWIW Rock auto has Timken bearings for just under $200..http://www.rockauto.com/en/moreinfo.php?pk=1117810&cc=1377569&jsn=462 Dont know if that helps but it beats $300 apiece.
  19. I think mine sees somewhere between 7 and 10 psi when cranking. It has been a while since its done it so thats the best I remember. Disconnect the lift pump and see if it busts right off. That would confirm to much pressure for starting.
  20. Mine is not HF but it is Auto Zone. Maybe a notch above I dont know. I have put a lot stress on it with a cheater bar and never felt like it was going to break, but the thought is still there when you load it up. You still have to do some beating like Mike describes. It worked real good on my front u joints. Still had to do some beating just to shock things loose.
  21. Mine will do the same just out of the blue every once in a while. I just dont pay it any attention it happens so little. I know thats not what you want to hear, it is just how I choose deal with it.
  22. I be surprised if it did not already have the additive in it. Only saying that since it says Limited Slip on the bottle. Could be wrong.
  23. Aren't the ball joints on a 99 in the knuckle. If so you could take them off and have someone press out the old in with the new ones. I know the 02 is in the axle. I used a press on the uppers but had to beat the lowers. My press kit did not have a receiver cup to use on the lowers. The track bar is easy. I have heard a lot a bad things about Moog lately. I used all Moog about 100k ago on mine and they are still holding up but getting a little play in the right front ball joint. Tie rods ends are good. The track bar only lasted about 80 and was shot. Federal Mogul must of cheapened them up. Sad to hear. @Mopar1973Man be careful with that torch. Remember what happened last time.
  24. With what these older trucks are bringing these days, especially clean low mileage ones, it is not surprising. I do hope you get it back and the dirty SOB's that took it get theirs. Drove NC to MO yesterday and did not see it on the interstate any where. Headed back later today and will keep an eye out.
