Everything posted by dripley
how much can you haul in the bed?
With that i might go for three cubes.
six axles or wheels?
I think having the load spread entirely thru the bed is the key. at least that will put some of the load towards the front axle. I had 1 cube and 3 straps from the tailgate forward and to the last 2 straps and loaded them at the front of the bed try to get some weight forward. I would think the long bed would be a little better since the rear axle is a little further back from the front of the bed. But either way that is an impressive load in the bed to haul. long or short. Especially without squatting the truck. Hope i dont have to do that again and haul it 85 miles though.I would have liked to have known what weight was on the rear axle. Then again maybe its better not to know.
Turbo delete
They hammered the kid in the thread mike posted and the other one i origanlly saw that was 20+ pages. but in the thick of them there were a few voices that spoke like ISX about it, but they were drowned out big time.I wonder if we can mass produce the delete kit.:lol:I blew a boot of once cause i did not tighten the clamp. I never noticed wether it was smoking but I darn sure notice the absence of power.
Airdog and fuel pressure
Close, but no ceeeegarrrr!
2 cycle oil
I have been running it for just over a year with no bad resulst. I agree with ISX and show us what you found.
Just throwing this out there. I connected mine to the alternator and do not experience the voltage drop when they are cycling. Am I isolated from the voltage by being connected there?
Turbo delete
I saw that one the other day and figured it was going to be a repeat of the kid wanting more smoke that turned into a 20 page coal raking. I do like the delete though. very stylish.
Biodiesel
I ran B-5 for a couple months out in OK. seemed to work OK. But that is the extent of my experiance with it.
NEW Guy help please
as long as it is grounded you should be fine.
Might be the reason. But if i remeber correctly that was one of the power options listed in the instructions. Move it and see what happens.
My 96 did not have overloads and I hate to think how squatted it would have been with 2 cubes. I dont really care to put that much in the 02 again anytime soon.
Surging
on cruise it just feels like something breifly pushes on mine like a head wind. no skip just kind of a weird feeling.
LED trailer lights
I bought some marker led's at Wally world for $7. I think they had the trailer lights too, but dont remember what they cost.
Surging
I have been feeling something very much like driving into a gusty wind like you say. Just every once in a while. i can feel it but all of my gauges are holding steady. Mostly hilly country where I am driving so the movement in my boost gauge is the only thing i see. Not sure if that is due to grade changes. a subtle change will make the boost move up and down. When you say surging I am thinking the rpm rising on its own which you should be able to see in the tach. But if it is what I am feeling you have to be quick to the gauge to see it. I cant see it but every so often i feel it. My injectors are leaking at the head and I attributed it to that and until i stop the leak I am leaning towards that for what I am sensing. Is this any thingclose to what you are feeling?
I wish I would have had a trailer. That was more weight than i cared to carry in the bed. This had to be a one trip deal due to the brick yard not being open on saturday.
NEW Guy help please
as long as your sender is grounded you should be good. just be sure your sender is after your last fuel filter. I still use the oe canister in addition to the AD filters. My tap for the gauge is between the oe canister and the VP.
Surging
How did you check for codes? Do you have a fuel pressure gauge?
I have seen several threads on how big a load you can pull. How big of a load have you hauled in your bed. I just had to go after brick for my mason. I put 2 cubes of brick in the bed. That is somwhere in the neighborhood of 6k pounds. The truck had plenty of power to haul, my rv out weighs it considerably. the first cube put it just above the overloads and the second cube put hard on them. I was able to get the load centerd in the bed(2 cubes=6'-6" long) which helped put some weight to the front. But i was really suprised she handled that much weight in the bed as well as it did. She sat level, rode great, steering was a little light but handled pretty normal,when you hit a bump you could tell it had a lot weight in it. Just curious how much any of yall have toted.
chat room
I know your working on it. could not resist that one since ISX brought it up.
chat room
Could it be bailing wire is a poor condutor of electronic comunication?
What trips your relay?
I have the ADII 165 and do not experiance a pressure drop with the cycling of the heaters. My question would be where are you getting your power for the pump from? My relay is plugged into the oe harness for the oe lift pump and the 12v power comes off of the alternator. If you are wired into another power source that is affected by the heater cycling you would get a voltage drop to the pump and lower pressure during their cycles. That would be my thought anyway.
Frantz by pass for a transmission filter
I have been driving a manual forever and dont know any thing about the set up. Not sure that i have seen any body with that particular set up. Hopefully someone will chime in with some knowledge of it.
Changing coolant question..... Distilled or not?
I am thinking the same thing on my current tstat. Running thru that heat cycle did something to it and it now functions better. As far as a 195* tsat, I have tried several differant 190* and a cummins 180*. whats $30 more for a 195. Next chance i get I will throw one in and see. When its all said and done I will soon be opening a used tstat store. Come by and have look at our inventory. Drip's Used Thermostat Store Fluctuation is our specialty
