Everything posted by dripley
Dead Truck
I have heard here and elsewhere you can run a SO on a HO, but not a HO on a SO.
Dead Truck
The 6 speed is an HO. The 5 speed and auto are SO's.
raptor fuel pump
Is there a possibility there is no check ball in the regulator assembly. It looks like the end of the regulator assembly fits the seat. I could not find an exploded veiw of it at the Pureflow site.
almost done my truck but need last minute opinions
If you do put a fp gauge in the pillar mount, drill avery small hole in the bottom of the pod the gauge is in. If it starts leaking you will know very quickly. I have a mechanical in mine and did that when i installed it. It did leak about 3 weeks later and i knew before it ran down the pillar and made a mess. I still run my finger over the hole every so often to be sure all is well.
Changing coolant question..... Distilled or not?
I have been using well water at home for the past 20 years and whatever came out of the tap anywhere else. Mine looks verymuch like Mike's. I never really gave it much thought. I dont have any staining problem with the well water, it is fairly clean. Never had any problems with the vehicles either.
intermittent miss on 3 different trucks
Have you tried disconnecting the edge/bully dog and see if the miss is still there?
1800 miles 12.5 mpg towing
1800 to 2100 is a good cruising rpm for me. i will go higher when pulling a grade, maybe 2500 or 2600. It all just depends on the situation I find myself. No dyno sheets here, Ijust do what feels right.
Silent Monks Singing...
I kept trying to figure out how those guys wer flipping the signs with their feet. I finally caught on.
p1693 + P0500...
I like Rogan's explanation better. Rain and bigfoot make tires spin=P500.:tease:I like your version too Mike, thats how i learned about it.
p1693 + P0500...
Spinning the rear tires will generate that code. I have set it in mine several times.
Heated mirrors
Did you already have heated electric mirrors? Not tow mirrors just regular ones.
2nd Generation Dodge Cummins Fuel System Explained in Video
That was good Mike. It backs up what i have learned here about the fuel system. I appreciae it.Do they have one about what the fuel does inside of the vp?
Well done and very imaginative.
Start up idle time
I usually idle mine for 30 seconds before I move. then I dle out of the rv park I am for another 2 minutes, then on the highway at under 2k rpm until I see the tempgauge move up or the oil pressure gauge start moving down. This for 25* and up, if it is colder i will idle it a few minutes more. I still take it easey until i see one of the gauges moving. I very seldom see any temps out of the teens. You might consider pugging it in for temps that lower than the teens.
I do agree with what you are saying. That is why I asked pepsi how fast he was driving. If I am traveling the Interstate I run the speed limit, be it 55 or be it 70. I know slowing down will help with the mpg with less wind drag and speed. Most of my trips start on Friday afternoon and have to be at work on Monday morning so a sacrifice of mpg for less time on the road is personal choice i am willing to make.
My truck chugs random, HELP!!!
happy to hear you got it fixed.
I have never seen over 10.3 in mine since it was new. How fast are you driving to get 15?
Heated mirrors
The 03 mirrors will not fit the second gen.
Front hitch??
naught + naught = naught, right? or is that naught X naught = naught? where is Jethro when you need him?
If you can find it under the plumbing:lmao2:. That is another reason i love it, open the hood i can see the engine front to back, both sides. it runs, pulls, and gets better milage than when it was new. Upgrades have provided the mileage, but the rock solid engine has provided the foundation for that.
Front hitch??
you dont need a front hitch then, just 5 miles of cable. tow yourself.
Merry Christmas
santa has already stopped by here in /columbia Tn. Diesel went down to $3.65 a gallon here.Merry Christmas to all of yall.
Injector Help
Mopar has a point on the mpg. The Fass DDRP might have a hard keeping up time bigger injectors also. Do you have a fuel pressure gauge to keep up with how the pump is working?
1998 dodge ram 24v cummins 3/4 ton 4x4 automatic wiring issue.....need help
First all 2nd gens have a PCM and an ECM. The PCM is on the firewall. It seems a lot of co's. get that confused. The ECM is on the block below the fuel filter canister. It has a 50 pin connector on it. If i am not mistaked the ECM does feed info to the cluster. Please post the codes that you pulled so we can see them. When my ECM went i had codes out the wazoo. They seemed to change sometimes. It was very confusing. If it is the ECM none of the codes are legit. I ran the diagnostic on my cluster and it said it was bad. Now i have a spare cluster. Same thing on the coolant sensor and the apps sensor. I now have spares of both of those. By any chance is one of the codes P 606? That is ECM death code.
Blower Motor
the blower motor will pull out from the bottom. there are 3 or 4 screws to take out and as I remember at least one is hard to get to, but other thatn that it is not to difficult. A Haynes manual has it covered or the FSM has it also.
