Everything posted by Sycostang67
Best batteries for our trucks
I have gotten the most use out of Les Schwab batteries. I was replacing the terminals on my mother in laws excursion when I noticed her battery was 10 years old. The one I had in my Mustang lasted for 8 before it refused to take a charge. It currently has a super start(O'reillys) in it right now going on 5 years, with 2 of those years spent on my trailer running a winch while the car was apart getting resealed and building the transmission. I tossed a maintainer on it for a few weeks and it's been working great since I put it back in spring of last year. Many years ago I had a 1980 Ramcharger with a generic gell cell type battery, optima knock off I guess. I was climbing a hill when the battery retaining bungee cord let go and the battery fell on the exhaust manifold. It melted through until the terminal touched and the truck died. After my buddy put rocks behind my tires, I put the battery back in the tray and tied the bungee back together and the truck fired right up. I was pretty impressed, I figure I would have had an acid bath in there with a regular battery and possibly a no-start situation. That battery lasted another year, the exposed area eventually corroded and would still start the truck if it started right away. It had no reserve capacity and would only give me 2-3 tries to start it. I miss that Ramcharger, it was the second truck I owned that shot fire from the tail pipe.
My daughter....
Smart kid. I do love those 99-04 mustangs, I had a 2000 for a couple years and really miss it. I would love to have a blue Mach1 though.
Banks Monster Ram with Ppump 24v
My bad, it wasn't 2 grid heater spacers, it was one and then another spacer about half the size. No mention of anything rubbing.
I saw one guy solve that problem by stacking 2 grid heater delete spacers and getting studs cut to length to bolt it all down.
LED lighting - Interior lighting
If you are missing all that stuff, there is a harness with new switches you can get on Amazon for $35. It's for the overhead console without the data display but it can still be used though. I just cut off the plug and spliced it into my harness, had new switches and sockets. The only down side is that it's mopar, so most likely the same crummy quality. I don't use the map lights though other than when they automatically come on so I figure they will last longer and a least my lenses don't rattle anymore. I also put LED bulbs in mine so I wouldn't have to mess with them at all.
Dash Frame Core Mount Deck Assembly
I'm in the same boat right now, my head light switch is floating behind the dash and my HVAC controls are barely holding on. I keep watching for a dash core on ebay within 500 miles which is about a tank of fuel. I'd rather spend a day and $120 in fuel to pick it up than $4-500 to have it shipped. I'd rather see it in person first anyway to make sure it's in good shape. Who knows what will happen during shipping.
Running board pics!
Mine are N-Fab, they offer no protection from road debris but are real handy for getting in the truck and getting in my tool box. I just installed them this year so I have no idea how they will hold up to the weather.
Knocking brakes
I haven't had anymore issues with the knocking and I have both non slotted rotors on now. We surmised there must have been some kind of fluke in the machining process. Dennis, the guy who sells these kits says he orders 2000 rotors at a time and has only had 8 people experience this problem. He offered to send me new rotors or reimburse me for the ones I had purchased. As I am tired of taking the wheels apart, I opted for the reimbursement. I could probably get the other rotors turned and use them but the car works so I am happy for now.
Height Sensing Proportioning Valve TSB 05-04-98
Wow, my 1986 F-250 had a system like that but my 1993 F-250 didn't. I figured a better way had been discovered. I didn't know they used those on Dodge trucks as well.
Filling oil filter when changing oil?
Mine is always full to the bottom of the threads. Speaking of oil changes, I know what I need to do this afternoon.
I accidentally started my truck with one of the filter head ports open. That was a geyser for sure, didn't get to celebrate like Jed Clampett though, just went into panic mode trying to shut it down.
Rear Brake Hard Line
I had a pin hole leak form on the rear line on my mustang this spring. I cut the line on the hole and put a compression fitting on and it's held great all year.
Low stall torque converter stalling engine
I've got a low stall with stock injectors and no issues.
3rd Gen Front Brake Upgrade
I did this swap early this year, I was pretty surprised at the difference it made.
Knocking brakes
I replaced the side that was knocking with a non slotted rotor, knock is currently gone, will continue driving to see if it stays that way. If does then I will swap out the other rotor as well. The car isn't pulling either way so I didn't see an immediate need to change the other one yet. If this doesn't work I can at least return one rotor.
Dash bessel removal
Getting the bezel off without breaking the dash or the bezel is the real trick. My bezel is currently held on by 1 factory clip, a metal brace I made and a piece of gorilla tape. That lense comes off pretty easy when the bezel is out of the way. When you get it off, hit with some mag/aluminum polish, that will help remove any light scratches. I have used clear plastic polish before, but the aluminum stuff just seems to work better. I'll use a half inch paint brush to dust around the needles on the cluster.
Knocking brakes
I just decided to order some new non-slotted rotors. I'm getting tired of pulling the wheel every 2-3 days to change something. Hopefully that will fix it and I can enjoy my car until winter.
Understanding your stock turbo!
Sycostang67 replied to Tittle Diesel Performance's topic in 2nd Generation Dodge 24 Valve PowertrainI had wanted to do an HX swap on my truck but couldn't find any when my HY crapped out. I ended up getting a new HY for the cost of a rebuild. I guess my old turbo was pretty wasted as the truck drives totally different now. The boost builds quicker and I no longer sail past 1200*. I'll be keeping a lookout for a used HX, but at least for now the HY is keeping a grin on my face.
Everyone post a picture of your truck!
I don't believe for a second you made that bumper, you better make me one to prove it. Good looking truck.
AC blower motor somtimes not working
That's what mine was doing, I would start the truck and no air movement. It would suddenly come on a mile or minute down the road. It would work on all speeds, but sometimes changing the speed would cause it to stop working. New resistor and motor and no problems since.
Knocking brakes
It will happen even if the rotor is stone cold though. I live on the corner, I back out of the driveway, pull forward 20' to the stop sign and it's already knocking. I was thinking of having the rotor turned to make sure it's flat and I can look for cracks as well.
Knocking brakes
I wouldn't want him to send me another kit, I'd rather find the defective part and have him send me a new one of those. Since it's a group of people who have recently purchased this kit, I'm wondering if something from the supplier is messed up. Hoping we can get this figured out before anyone else has to go through it.
Knocking brakes
I have, he's trying to help as well. It's just that he's sold hundred of these kits with no issues but suddenly 5-6 people are just now having problems. We are all trying some different things to see if we can fix it or find the cause.
Knocking brakes
Well I just ruled out the wheel weight, I only have one and it doesn't come anywhere near touching the caliper. I guess I will take the rotor in and have it turned just in case. If that doesn't work then I guess I will have to blow an extra $200 on some flat rotors.
Knocking brakes
I figured I would throw this problem at some fresh eyes. I have a 1967 mustang, I recently did a front disc brake conversion on it with slotted rotors and 4 piston calipers. On the first test drive, there was a knocking sound right away when applying the brakes. Upon investigation I had misread the directions and put the rotors on the wrong sides. Swapping them made the sound go away instantly, however it came back a few days later. This time I swapped the pads around and once again the sound was gone but came back a few days later. I have isolated the sound to the passenger side, at which point I swapped the pads on that side, inner vs outer. The noise went away and came back after a few days. This time I removed the pads, beveled the edges and swapped them again. The same thing happened, no sound then it came back. I have a 4 page thread going on my mustang forum, apparently a few other people are having this problem as well. I even have the gentleman who sold the kits trying to help out as he said he's never had this complaint until recently. The sound can be felt through the pedal and is loud enough to echo off buildings. It's only present when applying the brakes and the frequency will slow down with vehicle speed. I've included a video of it happening. Any ideas you guys might have would be appreciated.
