Everything posted by Evan
Quad tune 7x10 DD and race
I want a quad ? I'm fiddling with the s03 feels like playing the lottery. Gota get the numbers just right but dont know what the numbers are Heres my floored egt. Lol. Cruising to
I'm same as mopar man. 3200-5000. Our trucks can be tuned leaner. Less air less dense than sea level.. At sea level fuel/ratio will have more fuel in the charge and make more power. Than up at higher elevations. Maybe more heat to. Is your waste gate opening? I saw a very noticable reduction in egts with waste gate turn buckled shut. My stock hy35 goes over 35psi. But I rarely see over 30 driving normal. Are you standing on it to hit that 1250 on the flat. I used to hit 1400 with my foot on floor locked when I was making only 22psi. Now I'd imagine I might be able to hit that still but I'd have to be trying very hard to do it. I cruise at 1800rpm at 700-800 deg and less than 10psi ov boost Whoa them are skateboard wheels. 10mph difference at same rpm.
47re valve body look see
Dynamic. I'm hoping to drop the pan and up pressure today. I hope. I'm just shy of 150 right now. With the plate drilled .106 would bumping pressure to 165 be okay? Maybe 170. 3 or so revolutions on the pressure screw maybe 4. 15-20psi should change everything noticably Thanks for all your help.
Fte muffler day
Got my 2nd twister muffler. Actually the 4-5" is flop pro and the 5"6" is fte. Quality is a little lower on fte nit it has solid looking welds. Truck is now much quieter with both resonators on. Maybe even a stockish sounding idle with a slight turbo whistle. It does seem to whistle more when on the throttle I am very happy. No drone now and much quieter.But still enough good sound to be noticed. No ratty straight pipe sound or like how the straight through mufflers sound. Everyone around it has commented asking if I put a different turbo on. Finished very nice quite sound
Did you go 285x75x17 That's what I run. They measure an actual 33" tall I think 11 wide. They're a closer to 35" tire than 33" I'm about 9500lbs empty 7x09 on hy35 turbo Cruising at 1800rpm is the sweet spot for good mileage on my truck. I also have 3.55s. I dont check my mpg religiously though I'm hoping to make 600 on this tank of fuel
Transmission hangs in second
Not running between reverse and drive
47re transmission line leaking
I've seen those come loose, put a wrenches on it. See if snugging it fixes leak only thing I can think that thing does is warm fluid to operating temp. I've thought about bypassing it and running lines straight to cooler
Can the converter even drain in reverse or time it takes to move stick to drive
Smarty s03 today :)
Say I change timing to 2 I know they then all set to 2. Does eachcurve still change compared to two setting in each sw# or are they now the same. I'm mainly messing with sw5. But got to think that it may be the same as sw3 if its revo settings match sw5. I'm at tm5 timing2 d5 Wish I could go down to tm4.5 Sw6 is tm5 t1 d5 was timing set to factory causing it to fall on its face with the added fuel down low and up high. Timing set at 2 I haven't noticed it going flat. It will smoke like coal train but cleans out quick and is smooth my boost gauge isnt dancing. I was thinking to leave timing at 2 then bounce through the sw#'s see if one strikes my fancy. Might bump my trans pressure up 20lbs or so tonight and kick my shift points back. I do like fuel on the bottom. I might run around with pressure gauge on trans and watch shift points psi in different settings. Does this ever end
Smarty s03 today :)
Lol. I can tell the smarty does something what im nit sure. I was in sw6 this morning on throttle maybe alittle more aggressive th hen normal shifts 1-2 2-3 locks 3rd and fell flat on its face. All shifts felt natural good quick shifts then it falls flat I let off the throttle. My brain is turned think tranny. I'm back on setting sw5 tm4 timing 2 duration 4. Seems better just light throttle in city traffic. Did hit the freeway for a few minutes cruise has a slight surge. Boost gauge not fluttering grrr I have seen some settings really flutter my boost gauge. Some settings the needle is solid. Still not sure what to think. I thought all fuel setting would get rid of wierd neam nit I'm guessing it was fueled out when locking the converter in 3rd. Still more testing. Almost like loading rifle ammo trying different combinations till happy below essivive pressure signs on the primer.
Smarty s03 today :)
I've read the article.. I have 7x09 and decent auto trans. I'm really not sure what to think of this s03. I can feel it makes power but it's all wierd every where. About the only noticeable change I see is in tourqe management revo setting.. 3 less smoke 4 more noticeable scale and pep. Not sure injection timing makes much difference Still playing with it. I'm on sw6 now all revo settings at default
Smarty s03 today :)
Lol I cant sell anything. Maybe MoparMan can log onto my account and finish my profile. Its stuck on step 3
Smarty s03 today :)
Ok. Started thinking I didnt like the smarty much at all. Tried sw3. Tm 6 t4 d3 felt good on bottom pulled hard then went flat around 1800, wtf maybe timing turned down to 3 would help. So I went back to sw5 tm4 felt good before so i used that but tried timing at 4. And duration 3. This feels good of idle I could hear turbo spool up quick. It's dark and my psi gauge has no light in it. It pulled hard off idle to 2000 feet crisp and no dead spot. Only thing I didnt like is 3rd locked early. ive been wanting to bump my trans pressure up, this will up pressure for reduced TPS and make shifts later. I might tear the valve body off and go after the 2-3 shift port in the plate. I've been wanting to crisp and quicken 2-3 . It never ends. I'm going to leave it on sw5 tm4 t3 d3 for the time being I feel it's the best driving settings I've tried so far so I'll give it some drive time to decide. As much as I like tunning I was getting irritated with the s03. Was excited that I could feel power but it seemed all wierd. Hoping this last setting works seems everytime think I like it it feels weird the next day. Maybe it always will. Lol. Anyone wanna trade two shitty programmers for a quad?
Headstuds
Hx40 would be cheap and easy
Headstuds
60 60 12 sounds like me. I dont like to go much over 2200rpm
Headstuds
I filled out sig but it wont take it. 7x09, exhaust, bhaf, s03, 47re has alot of money. Ohh 150 pump big line from tank to injection. Essential gauges to. Undecided on s03 also have a superchips. May get rid them for a turbo. Hx40 pr something cheap Usable 350-400 is what I'm after. Ok to over 400 if usable.
Headstuds
Mostly I've met my power goals. I'm at 295k and heads never been off. Even if gains are minimal to nothing I'll most likely do some grinding on exhaust side when it's time. Myswell since I do what I can when I can when all it costs me is time. Studs, valves, deck, grind. Possibly lip in intake since itl be at the machine shop. Put a few thousand at it maybe 2500. Plan for doing it at tax time. We just had a shoo do our 6.7 for 3500 I was unimpressed with what we got for 3500. But that was labor and all. I did zero wrench turning. Actually made me sick knowing I could have got more for 3500. But I'm not the boss or money man so he did it how he wanted and truck couldn't be down long. MoparMan I'm at 7 8 psi cruising same speed as you. 10 on little inclines. Not really sure what mpg I'm getting. Better than our 6.7 though for sure. I just can't run small tires. Not in my blood
Headstuds
What upgrades are recomended when doing a gasket. Studs plus what. Aside from guides and seals. Can we port match the manifold or do any porting maybe open up the exhaust side to breath better or is that a no no without a flow bench and proper tools to ensure each exhaust ports the same size coming out of the head. Dammit now I'm going to research porting. I'm at 295k heads never been off
Smarty s03 today :)
You mention s03 a few times as the only tune you recomend to run. Does it differ from what's mentioned above. Why is tm2 so weird I couldnt pull over fast enough to change it? My mind was thinking TV cable came unhooked somehow. Though if cable was unhooked it would shift sooner. I doubt I'll see any high tempts. I'm use to seei g high temps I drive by the gauge anyways. What I dont want to do is blow the head gasket pulling a grade. I have been keeping rs up more. My tranny I can kinda lug around like a manual lugging its probly a bad habit to get into anyways even without the s03 on. I do want a quad I like to tinker so that would be right up my alley. I'll try s03 tomorrow like I think you advice and may do some testing on even numbers though I doubt t I'll see much there. Fuel only tunes. Thanks again for the advice it's all confusing and interesting seeing how trying different things effects the driving characteristics
Smarty s03 today :)
Hitting the freeway from boise ti mtn home Switched to set same revo settings. Oddly 5 is more aggressive down low. Just switched back to. Gona cruise home. I like the settings I'm at so I'm trying the different od numbers. Sw 5 tm4 t3 d3 ti smokey throttle felt weird shifts off to. Sw7 feels better all around noticably less smoke. I do see a quad in the future. Hoping to find a all around setting for now in s03 that I'm happy with and comfortable towing. Might need two settings. One for towing and empty.
Smarty s03 today :)
I might try s03 with settings maxed pr st the upper end I am on sw7 tm 4 t2 duration 3 now. Tm 3 seemed kinda sluggish, well see if 4 livings it up just a touch. Keeping timing st 2 for now and upper end feels good with duration at 3 Tm at 4 compared to tm3 produced less smoke right off an idle going stop light to stop light. Quicker through the gears using moderate to light throttle. Sometimes almost no smoke. Didnt get on it much just drive normal. With tm4 timing2 d3 on sw7. Still be a head gasket killer(towing)? So far I like these settings on sw7. I'll try these same settings on sw5 next. Thanks for all the replies and and advice Was a good day. Messing with tunes and fabbing parts
Smarty s03 today :)
Sw7 tm3 t3 d3 Cruise control on ,psi 8-10 slight surging but livable. Lots of giddy up passing Egt tunning 750-800. Fair amount of haze/smoke accelerating to 85 passing So far liking this. Hitting stop and go traffic soon to see off idle smoke Went through 4 green lights. That almost never happens. From what I saw it roll black easily but cruising smoke is reduced. Dow shifted to second to keep from plugging around 25mph. Rpm 1800 will smoke but cleans out very fast
Smarty s03 today :)
Woah. Tm at 2 undrivable. Light throttle had to let off to make all shifts. Would not shift through the gears unless I let of. Setting to 3 now um maybe 4.. Loading tm 4 t3 d3 sw7 now Catcher7 Tm4 timing3 d3 Shifts well quick, lots of smoke Trying tm3 timing2 left duration at3. Loading torch and hoses in truck nowdark rainy Tm3 did reduce the light switch throttle alot. Didnt get on it much to tell what the butt dyno reads. Going to put a few hundred miles on tomorrow on catcher 7 at tm3 tw duration 3 and see what I think. Not sure what was up with tourge management 2. Wont ve trying that again.
Smarty s03 today :)
Now 7 Tm2 timing 3 duration 3. Trying to see if revo settings do much Read 4 pages in the other thread. If I understand right torque management low numbers will fuel less off idle.
Smarty s03 today :)
Loading #5 Adjust options set set to below. I think Torque management 4 Injection timing 3 Duration 3
