stodg73
Everything posted by stodg73
  1. Gonna be at work for today. Gonna have friends, co-workers and family over.
  2. P0123 Throttle Position Sensor, High VoltageP0336 Crankshaft position sensor "A" range or performance problemP1690 Fuel I/P CKP does not agree with CKP P1693 Diagnostic Trouble Code set in Companion Module(No Worries)P1694 No CCD messages received from the ECMYou need to check the Crankshaft Position Sensor, wiring, etc. possibly need to change it out. Others will chime in.
  3. Glad your family is ok. Thoughts and prayers with everyone.The reason that the xrays were sent there is because there it is daytime, they are not paying OT for a doctor to read them.BTW, I am a paramedic.
  4. P0232 Fuel pump secondary circuit highP0215 Engine shut off solenoid malfunctionP1689 No communication between ECM and I/P module
  5. Gauge Install Look in this thread post 10 for the HF fuel pressure tester link.
  6. The Cummins has software that you enable to have the 6 cylinder high idle or the 3 cylinder high idle. When the 6 cyl hi idle kicks in, the RPMs go up to 1200. When the 3 cyl hi idle kicks in, it sounds like the motor is tearing itself apart. It sounds horrible. With the 3 cyl hi idle, the VP-44 cuts fuel off from 3 cylinders causing increased resistance, therefore increasing temps.
  7. Welcome from Southern Colorado. If you get up here, we can load the programming for the 3 cylinder and high idle onto your truck.
  8. Welcome from SoCo.P0500 Is a Speed sensor, no worriesP0463 Fuel level sensor circuit, high input Fuel Tank P0460 Fuel level sensor circuit malfunction Fuel tankP1693 Diagnostic trouble code set in the companion module Code set P0523 Engine oil pressure sensor/switch circuit, high voltageP0238 Turbocharger Boost sensor A circuit, high OverboostP0236 Turbocharger boost sensor A circui8t, range or performance problem Overboost or stuck wastegateP1475 Auxillary 5 volt supply voltage too high P1688 Internal fuel injection pump controller failure New Injection pump neededP1693 Diagnostic Trouble Code set in companion module
  9. I agree with ISX, however you can go up to 1250* for less than a minute. I have no experience with the cortex programmer.Where are you at in SoCo?
  10. Death Wobble Read this and it may just be what you are experiencing.
  11. It should not hurt a thing.
  12. You have all these codes. LOOK HERE Looks like the PCM needs cleaning.
  13. Since the truck is a '97, you might be able to pull the codes with a code reader. OBD II were placed in '96 and very rudimentary then.
  14. Then there is something wrong in the mechanism of the parking brake. When you changed out the switch, you may have changed the depth of when it turns off.
  15. Make sure that the pedal can travel up all the way. There may be something caught in the mechanism that is keeping the pedal from going all the way to the stop.
  16. Welcome!
  17. Sounds like you have one of our bears there. They come and eat the peaches off the tree and the plums in the neighbors yard as well.Along with spilling the trash out all over.
  18. You could get something like this. Coolant Heater System
  19. I had to purchase 3 different manuals in order to get everything I needed for my truck. If you find one that has it all, please let me know.
  20. Looks like things are coming together.
  21. P2563 - Turbocharger boost control position sensor - range/performance.You need to check the sensor if possible and also do you have the waste gate altered? Check to make sure that the turbo is good working order. Check the wiring at all connections that you can see, one could be loose or corroded.
  22. Congrats on finding a better deal.
