CUMMINSDIESELPWR
  1. i try not to lift it on the pumpkin, if i have to i will but most times i jack one side up under shock mount and jackstand it.
  2. good to have ya back mike!
  3. i figure they are a local shop so i wont pay shipping, getting it done right by pro's is what matters to me so its all good:)
  4. the ins company are idiots.... such a waste...
  5. so a local shop does full rebuilds on turbos for appx $350. imma get the turbos rebuilt and have a good spare. -------- Hi Randy, For an HX35W, the starting rate for a rebuild on this turbocharger is $350.00. The $350.00 includes all new bearing, seals, bolts, thrust bearing, thrust collar and new clamps. We test your actuator to make sure it is within spec. We will check for shaft straightness to make sure it is a completely level surface. All the housings (Compressor, turbine & bearing) are all placed in ultrasonic cleaners. Then they are bead blasted and glass blasted as well. They will then be sent back into the sonic cleaners once more to make sure all of the blast material is out of them. The bearing housing then gets honed and the other housings coated. The turbine wheel gets polished and then re-balanced with the compressor wheel. Then the unit will be re assembled. If we find anything out of spec that we do not feel comfortable using, such as a housing and or wheel, we will price it out for replacement of that part or give you the option of how you want to further pursue the rebuild. Please contact me if you have any further questions, Thanks Mackenzie Flynn Turbocharger Product Manager Phone: (303) 428-3611 Ext: 205 Fax: (303) 428-6785 E-mail: mflynn@centralmotivepower.com Facebook:https://www.facebook.com/CentralMotivePower ----------- mods if anything needs to be removed let me know?
  6. ill need to have a spare one of these in the truck box in case!
  7. battery chargers put a forced charge on the batteries causing heat and some chemical reaction causing bubbles to form on the plates that directly displaces water. gas also vents too. when the vehicle is running, the alternator "floats" the vehicles load over the batteries. the batteries are not being drained as the power is going to the vehicle through the battery. this is why you see on DC power plants with battery backup a "float" or "charge" switch. if the batteries are discharged below 100% the rectifiers will increase output to supply a charge current to batteries plus power the equipment tied to the battery string. same thing happens with a vehicle but its controlled automatically by the ecu and alternator. clear as mud?
  8. ouch, the only thing i use antisieze on are the front hubs.like dipping yer brake pads in grease...
  9. grew up in edgewater myself from 4 to 18 when i left for army. only things i miss...bikinisseafoodscubayear round riding
  10. welcome brother, vet to a vet, thank you for your service!
  11. had a thought, did you tighten the injector hold down plates fully? maybe one could be jumping?
  12. i will say this. having traveled to europe and a few other places, there is a HUGE and i mean massive difference between american blacks and human beings from africa or of african decent. never have i met a person of african decent outside of the us and not from the us behave as the thugs and gangbangers of america do. your daughter should recognize this difference, because i sure can. when people act like civilized human beings there is no color to me.
  13. be on the search for whoopin some arse! i hate people who cant leave others stuff alone.
  14. yeah, im in no need for anything other than stock. i have a mild build for reliability and im more than happy with the power it makes
  15. prosecution held back so much incriminating evidence again TM that the case probably would have been thrown out early.
  16. he is so how these idiots wanting revenge on white people for a death of a black kid boggles my mind...
  17. i so want to do this!
  18. glad yer back mike!
  19. I dropped the ball on purchasing a used hx35 from War Eagle last year and i got back in touch with him recently for the purchase and it went smoothly. It is in good shape as described and ill have it rebuilt then swap with my current and rebuild it as well for a spare.Thanks War Eagle!
  20. 60 mile drive to work and temps are normal.
  21. nothing racist about stating fact brother. the media is fueling a fire that didnt even need to be lit from the beginning. they will be the engineers of the riot stories they seek to cover by their own creation. im ready, downtown denver FNS-9 with 85 ready to fly to get me home.
