Everything posted by Doubletrouble
Nv4500 getting harder to get into gear
I appreciate it guys. I'm not worried about the layoff much. I should be fine financially. Once I got back to work after my knee surgery we padded our saving back up to where it was prior to surgery so should be good. I could actually use a little off time to get some things done here at home.
Well, it's official. I got the call yesterday, I am laid off for at least 2 weeks. Time to get some things done at home. Clutch parts will arrive today and I also ordered a new base with valves and such for the toilet in our camper. Unrelated but I'll have that today also. There's 2 projects already. If the weather will cooperate I should be able to get alot done. Back on topic, my grandpa was working on his farmall H when he learned the hand shake. He hit the starter button and sent it through the back of the barn. He's the one that taught me the hand shake. I see why. Lol. He passed away when I was about 12, I spent alot of time out here on the farm when I was young, I loved it. I try to remember everything I learned from him. As I get older it all.makes more sense but I also have a harder time remembering everything to.
I have a few old tractors with no safety switches what so ever. If I start one while standing beside it I was taught to ALWAYS "shake hands" with it first. Grab the shifter and shake to be sure she's in neutral. It has become a habit. Even if on the seat, clutch depressed I still do it.
The switch in the truck now works. I'm sure mike suggested replacing it as a preventative maintenance. I just don't want to replace a part that works, especially an expensive one.
that's rediculous.
Dap 7x0010 injector problems
- Nv4500 getting harder to get into gear
That's what I'm wondering. Is there really a shortage or is this china's way of getting our economy to go further into the crapper? I looked them up at rock auto, these are the only two they list. $58 seems a bit steep for what it is. Maybe there is one of those elusive chips in it?- Nv4500 getting harder to get into gear
I figured it was brake fluid. I ordered the master and slave. Thought best to just replace both. Decided to hold off on the switch, the one in the truck is working and those are expensive little buggers. Might be looking at another lay off due to this electronic chip shortage from china. It's really hitting the auto industry hard. So thought I'd save the money for the switch at this point. Once the parts arrive I'll remove everything, assemble with new master, slave and bleed bleed bleed. Then reinstall.- Nv4500 getting harder to get into gear
Do these take dot3 brake fluid or a specific hydraulic oil?- Nv4500 getting harder to get into gear
Found the video, thanks Mike!- Nv4500 getting harder to get into gear
I'll be getting an OEM type replacement. I don't see a need for the adjustable rod. It worked just fine before this, just want to get it back to where it was and won't have to worry about over-extending the slave. I'll find a video on bleeding the system and bench bleed it before install to avoid any issues if possible.- Automotive Gear Lube Study
I agree with @Mopar1973Man, alot of the studies I have read are skewed to the manufacturer sponsoring the study. Also, alot of the store brand oils such as walmart for example are made by better known manufactures so the quality is there just not the name brand. I won't knock amsoil because I do use it in my harley, it did make a noticable difference there but that is an air cooled V-Twin which see some pretty warm temps in the summer. Completely different animal compared to our trucks. The biggest thing is consistent maintenance in the form of oil changes or at least testing the integrity of the oil and good filtration.- Nv4500 getting harder to get into gear
Yeah, I'm sure it's the hydraulics now. The switch doesn't look good either. Time to replace both. Most of the kits come filled and pre-bled. Is there a way to check for air or maybe re-bleed the system before install?- Nv4500 getting harder to get into gear
I finally had a moment to check some things. As suggested, I checked for a little fluid flow into the reservoir as the pedal was pushed down. There is none. As explained I guess this means the piston of the master is not fully retracting to too off the master cylinder? That would explain the issue, not enough fluid being moved to provide the necessary travel. Hence having to be pushed tight to the floor. Any thoughts? On the right track? Thanks all. Also, when I pulled the clutch pedal back something gave way. I believe it was the safety switch pulling away from the master. Is that supposed to happen? See pics......- Lift pump issue
Is this relay there to protect the lift pump or the ecm circuit? I assume the ecm?- Knocking noise in bell housing
I don't know if camp lejune has them but some military bases have garages you can rent with tools and equipment available to use. My son was in the navy in san Diego, they had a shop like that. Came in handy for him.- Nv4500 getting harder to get into gear
Would what seems to be excessive free play point towards the hydraulics? The clutch pedal moves 1/2-3/4 of an inch if you pull up on it. Would this indicate a bad/broken return spring inside the master?- Garage tinkering today, might be interesting
No, I didn't. I actually scraped the idea. There just isn't enough room to get the belt to twist and turn the way I need it to. Would have been neat to get it to work but I had to move in to other projects.- Nv4500 getting harder to get into gear
There is a small gap I guess I'd call it where you can see the teeth of the flywheel. It looks dry. I would think that would get soaked in oil as well if there was a main seal leak. I will try looking at the bushings a little closer. Probably replace the clutch master and slave and see where that goes. I will pull the trans if needed after that. On a side note, how does one check the fluid and level on the nv4500. I'm sure I could search it but since I'm here......lol- Nv4500 getting harder to get into gear
It's only difficult when the truck is stopped. Like when shifting into 2nd or reverse. Once moving it shifts into 3rd, 4th and 5th fine as I accelerate.- Nv4500 getting harder to get into gear
Would the bushings for the clutch/brake pedal cause this sort of issue? I have noticed that when I press the clutch I can feel the brake pedal push back if that makes sense.- Nv4500 getting harder to get into gear
I tried pumping it up and that didn't help anything either. I did look under the dash and it seems to show some signs of leaking. The master also seems to move slightly when I push in the pedal. I'm not sure yet what is going on here, I know that something is different from before. Just have to get to the bottom of it.- Nv4500 getting harder to get into gear
I will try to pump it up and see if that changes anything. Holding it down to see if it bled off did nothing. It didn't creep or anything so I don't believe it's leaking.- Nv4500 getting harder to get into gear
I'll have to try that. Is there an inspection cover to take a look at the clutch. I've been under there but was really looking at that at the time.- Nv4500 getting harder to get into gear
Not sure if the age of the hydraulics, I would assume OEM? The syncros have went for 3rd gear already, I've just been "floating" into 3rd to avoid grinding it up. Just seems strange it came on somewhat suddenly. I will have to check the hydraulic slave somehow. I did have to top off the reservoir once, maybe it leaked and then stopped? Haven't added anything since. Truck only has 151k on it, hope the shift forks aren't wore yet. Idk. - Nv4500 getting harder to get into gear
