Everything posted by Doubletrouble
Injector questions, which vendors?
Have to admit I'm a bit jealous, a '57 chevy is probably my favorite car. Doesn't matter if it's stick or some what modified, love the body style.
I think you all have a few years on me. I remember gas being around $.70/gallon and mcnasty burgers were $.75 I think. The local mcdonald's here used to have $.25 burger night on Thursdays. Not anymore though. Now I won't even eat their food, it's horrible.
Block heater usage question
I had mine plussed in for 1.5 hours today before starting. I did not check coolant temp but it sounded much happier than if no block heater was used.
I haven't plugged in yet this year until now. Been a mild winter. This week though highs are in the teens and lows in single digits to -2 at night. Just thought I'd ask what others do to compare.
Just curious as how you all use your block heater. I am of the mind set that the more you use something the faster it will wear out so I try not to over use things if not needed. So that leads to: Is it better to leave it plugged in all night or possibly for a day or two at a time or would it be best to just plug in an hour or so before you fire it up? Any advantage to either practice? This morning the outside temp is 9° so I figured on plugging in an hour before start up today just to aid in warm up and easy cranking. It should start fine without it but I know it will be easier on the engine with a little heat in there.
Pre lift pump fuel filter question
I like the idea of not having to remove fuel line clamps and having fuel run down my arms and what not. The longer change intervals will be a plus as well. When you change filters does it prime itself or so you fill the new filter first to aid in priming? On a semi we usually fill the filters before install.
Ah, ok that makes more sense now. That's basically what I have inline now. I believe it's what came with the fass ddrp. There was one inline when I got the truck, since replaced with new Wix 33270 when I changed the filter under the hood.
@LorenS, the one i have is similar to the one in the pick of your link. Mine has larger threaded inlet and outlet ports that are at the moment reduced via brass barb fittings to fit the return hose on a log splitter. Will that matter as far as priming and or drawing fuel? @IBMobile, how does the line size affect filter part number. Wouldn't it be more dependant on base and thread size of said filter? Just wondering. I think when I do this I will probably use 3/8" line since I don't plan on going to far with performance mods. 3/8" should be plenty for 300hp or less from what I have read. Thanks for the comments so far.
That's what I was going for. I have a fass ddrp in the stock location now. When I upgrade the fuel lines I want to move it closer to the tank, install a draw straw to a pre filter then into the OEM filter housing and so forth.
This may be a little off the wall but you don't know til ya ask. I have a filter head from a log splitter, would I be able to utilize this as a pre lift pump filter if I can locate a filter of suitable micron rating? Has anyone tried this? What were your results? I'm just curious at this point. I would like to revamp my fuel system over the summer and add gauges as well so kinda planning things in my head since I'm sitting home bored. Lol. Thanks for any input.
Battery Temp Sensor question
I disconnected my grids over the summer as well. No point in wearing them out when not needed. Probably gonna need them today though. Temp is 16° with wind chill of -7°. I need to have grid heaters in my coat!
Crazy world we live in isn't it? Have to cover your arse everywhere these days. And with electronic fraud and hacking it's difficult to do especially if someone is coming after you for I'll reasons.
Drawstraw Users - How low can you go?
And that's behind the T-case on the inside of the frame rails correct? Looks like an easy install and easy to get to for filter changes.
Novice question here: Does coolant pass through the filter housing in some way or does the housing absorb heat through metal to metal contact? Might be a dumb question but I have never removed the housing from the side of the block so I don't know. Thanks.
I would have to look for a battery equalizer/charger then correct? I'm interested because I have lots of batteries. 2 in the truck, 2 in the camper, 1 in the grain truck, 2 riding mowers and 6 tractors and a combine. That's alot of batteries to replace, they aren't cheap.
Hey.... Just Morning Coffee and Wired Up Chat........
I appreciate it mike, not many people think.like that anymore. I actually had a similar thought when you said you were shoveling off a roof. I'm not afraid of heights but I know I don't heal like I used to either.
This is a process that still eludes me. I understand it to a point but not fully. I have looked a "special" battery chargers that claim to rejuvenate batteries but not sure if that is what's needed to do the job. I have tested both of my batteries before winter set in and they tested good. I then charged them separately to a full charge. Is this near what you describe? Forgive the ignorance on this.
Oh yeah, I'm not going to over do it. His driveway is only 2 car lengths long and about 15' wide. His snow blower is self propelled so it should be easy and only take about 10-15 minutes. He is one of those guys that lives in a sub division, not a real big yard but has a 42" riding mower, snowblower for his little driveway and so on. I chuckle about is sometimes.
While reading this my coffee is next to me. Got a call from dad last night. So I'll be heading to his place today to check out his snow blower. He says it won't start. Thinking he just wants me to clear the snow but either way he needs help so I'll be there. Was considering clearing our drive today but now temps are supposed to go above freezing tomorrow and calling for rain so maybe mother nature will take care of it for me. We have some cold weather coming next week. Temps in the single digits so I'll be doing what I have to in order to.prepare like getting my cord out to plug in the Cummins. I have plenty of wood in the basement for the furnace so I should be good there. I'll probably fire up my generator and let it run for a few to charge the battery just in case.
- Snow
Snow
I've heard cannabis helps for alot of things. My wife smokes a little to help with a digestive issue she has. It helps her alot. My parents have had several surgeries and been through a bad car accident in the past, they have tried edibles and say that they help. They just don't say much about it like they don't want anyone to know. They're older so they still think of it as bad. My drawback is I have a CDL so am subject to random drug tests, can't have any of that I'm my system. So I rely on ibuprofen and such.
Snow
I had that issue last night when trying to go to sleep. Lower back, hips and legs were just aching for some reason. Didn't do much yesterday because of the weather. Helped the wife with a few things in the house. That was it for the most part. I don't like this getting old crap at all.
Snow
@Mopar1973Man, your not planning on sending this next storm this way again are you. It's still snowing from that last one. As far as vitamins, I just had blood work done 2 maybe 3 times. I forget. The first was a wellness check for my regular doctor. They said everything came back good on that one. My most recent was checking for signs of gout since my left foot has decided to swell and I have shooting pains through it now. The knee (right leg) is doing well since the surgery. Been having a little pain the past 12 hours for some reason. Might have over done something cutting firewood on Saturday not sure.
I don't blame ya. Luckily the fire didn't reach you.
@JAG1 that's not a good situation at all. In our area forest fires aren't really a threat. I couldn't imagine dealing with that. Very scary.
