Doubletrouble
Staff
Everything posted by Doubletrouble
  1. My drive is gravel, creepers don't roll. I use cardboard alot as well.
  2. Have you thought about one of those cloth like sliding mechanics creepers? I saw them on one of those truck shows. Seemed to work good for them but I've never known anyone that has tried one. https://www.google.com/search?q=sliding+mechanics+creeper&source=lmns&tbm=vid&bih=512&biw=360&client=ms-android-verizon&prmd=sivn&hl=en&sa=X&ved=2ahUKEwiB0o6o8vvtAhVKG6wKHUTzBM0Q_AUoA3oECAAQBg#
  3. I saw this story this morning. The dodge ram truck plant in michigan is producing the ram TRX with the 700hp hellcat engine and somehow apparently one fell of a carrier on the assembly line. Then one of the employees decided it would be a good idea to leak this photo of it on instagram. The automakers are very picky about pictures being taken in the plants on a good day, let alone when something like this happens. The guy that took the pic posted it with his user name and a pic of himself in the profile. At the very least he will probably be unemployed very soon.
  4. How bout one like this?
  5. I would be hard to hide mine. There would be 4 black marks in the road
  6. I would have said the same thing.
  7. I just wanted to take a minute before the ball drops and all to wish everyone here on our little piece of the web a Happy New Year. I hope and pray that 2021 is better than 2020. It's been a rough year for me and my household. I'm sure we've all had our ups and downs one way or the other. Let's all keep our heads up, the rubber side down and the turbos spooling and tires spinning. Cheers to all and HAPPY NEW YEAR!
  8. Had I known the size of the o-rings or had a good selection of them here I would have done the same. That being the case I just swapped out the whole thing.
  9. Ahh ok, I misunderstood. I thought you were back at working on your steering box yet again. That's why I asked. On a side note, after reading about all the various issues resulting from oversized tires it really bolsters my feeling against lift my truck and running large tires. I'm all for that, I've had a few lifted myself but this one.....no, I'm going for longevity.
  10. I tried to stay away from rubber parts and the exhaust pipe. Would have been easier if the spray would have fanned out like a thinner liquid would. With a stream you basically spray the top and let it run down to coat things. Maybe with more pressure and a better spray tip I could get the fan spray.
  11. This kinda stated in a different thread but I thought I would post what I've done here instead of hijacking. There was a discussion about rust proofing and weather protection including the use of undercoating, fluid film and the old fashioned used oil concoction to combat rust and corrosion. Since I've been off work for a bit due to a knee problem I have been getting antsy and needed to get outside and tinker with something so I decided to try the used oil truck that was mentioned by @Mopar1973Man in another thread. I have plenty of used motor oil here on the farm (approx 35 gallons of it) so I mixed some with diesel to thin it out enough to be sprayed through a regular old garden sprayer. The type with a hand pump and hose with a wand. The mix worked out to be around 50/50 I believe. The diesel I used was off road diesel and seemed a bit thicker than road but maybe I imagined that, not sure. Anyway, mixed it in the sprayer, pumped it up and began to spray under the truck. I mainly covered the outside of the frame rails from in the wheel wells and layed on the ground to get the outside of the frame from there. I did not go down the center to get the inside of the frame just to compare later. The sprayer did not fan the oil like I had hoped it would it was more of a stream but it did cover and creep into tight spots pretty well. I parked the truck out in the grass afterwards to let the excess drip off. So far for money invested I can't complain. The black oil gave the frame a nice look and I've driven through rain/snow twice so far and the water just beads up, with the oil film on the metal the water does not penetrate. Will this "rust proof" the truck? I suppose in a way it would by keeping moisture, salt and such away from the metal and sealing out the oxygen with the film layer hence preventing the rust. Would another product be better? Possibly, I have only experimented with this out if boredom for the most part but so far, for nothing really invested I feel this would be a cheap alternative and use up some of that oil you don't know what to do with. See pics....... Just as a comparison, this is the dry frame, before coating.
  12. @Mopar1973Man is that on your Cummins? I thought you just went round and round with that steering box?
  13. Last update** So you finally received the fuel drain valve thanks to the stupid slow snail mail. Installed it 2 day ago and so far no more leak. Simple install, best done with a magnetic torx driver.
  14. Thanks for the insight @Dumb A, it makes sense though. The forces and actions of anything operating at a high speed changes alot of dynamics.
  15. I drive my 3500 dually 4x4 daily. I guess I'll pay whatever fuel is at the time but I won't give up my truck. Mine is mostly stock, summer milage was about 17-17.5 mpg. I'm sure winter blend will drop it some but I'll deal with it.
  16. Correct, unfortunately the rubber usually begins to break down over time and splits. If you don't see the split dirt enters and not long after your replacing the part. I have several antique tractors here on the farm, a few Farmall, a John Deere, ford and a couple Massey Harris. They were all equipped with grease-able bearings and such. So far I have yet to replace any. The ford is the newest at 1973, the oldest would be our Massey Harris 101 circa 1938.
  17. I was curious since I read somewhere that once Cummins supplied the engine dodge did a few things that fell short of the requirements. Can't recall what they were at the moment. I know the engine itself is a very solid and reliable foundation as long as it is fed properly. The dodge parts of the vehicle wear out before the engine does.
  18. My sister in law has had the Rona the past two weeks. She is doing well, she said she's been sleeping alot, no energy and some breathing trouble and fever but not as bad as what she expected.
  19. @dripley, that's basically what Geno's sells. It hangs behind the grill in front of the air cooler and stuff. It has velcro on the center flaps to control air flow. Seems to me that it may be more than I would need, it's also a screen behind the solid flaps to keep bugs out if the radiator.
  20. I guess I just like the idea of pumping clean grease in and forcing the contaminated grease out. Makes sense to me but I get the "maintenance free" side of the sealed parts as well.
  21. I made some cardboard inserts like what you have last year. I couldn't quite get them cut to fit as nice as I would like. I wanted to use them for a template to make some from a more durable material, stainless possibly. I've looked at the covers sold by Geno's and those seem to cover up quite alot. Might be nessesary somewhere else but I doubt here in ohio.
  22. Was that a change made by Cummins or dodge?
  23. Between the population rising and the ineffective masks that we wear as the public and the shortage of hospital bed and medical supplies it's going to get worse. I saw a story on my Yahoo feed that claims there is a different strain of the virus making its way into the stars from Europe that is more contagious than what's here already. I've been off work for a little over a month because of a torn meniscus in my knee so I've managed to keep my distance from most people. Once I go back though it may be a problem. My sister in law has it now so my brothers family is quarantined. We had to exclude them from Christmas because of it.
  24. And @Mopar1973Man, do you run any sort of winter cover at all when the temps dip to zero or below?
