Doubletrouble
Staff
Everything posted by Doubletrouble
  1. The way the mail is moving lately it may be longer than that. I ordered a water separator valve from RA 10 days ago. It was stuck in detroit for 4 days. I'm still waiting.
  2. I've used that more for a thin protective coating. You would have to spray 100 coats of it to make it a strong bed liner. Sprays on kinda thin.
  3. I have to believe that to be true. We are a rebellious bunch.
  4. I haven't taken anything major apart on mine, mainly stock with 150k but noticed a while back 2 of the exhaust manifold bolts had backed out about 1/8". I tightened them down and no issues since. Probably should put a torque wrench to them for piece of mind though. I agree with the above, I would bring her up to temp, listen for any odd noises and check for tell tale smells in the process.
  5. Wow, what a d**k. If I sell something I completely expect someone to look it over and scrutinize it just to try and talk me down on price. It's part of the process. To shut you down like that and be a jerk was really uncalled for.
  6. So in space a rooster would be a little horse?
  7. If a rooster crows I'm outer space can you hear it?
  8. I hear ya brother. I do get plenty of looks in my truck, I think because it's a 2nd gen and Cummins. Those who know these trucks want them. I've had 3 offers from guys I work with but I won't part with it. The 2nd gen body style was always my favorite dodge truck, when I found mine with low miles, and the 5speed I felt like I struck gold (especially for what I paid for it. I didn't even haggle with the guy). I wasn't looking for a dually but what the heck, never had one before so why not. I don't even know the trim level on mine. It's a basic work truck, manual windows and locks, rubber floor mat. It has a/c and am/fm cd player. That's about it. I believe it came with just steel wheels when new, someone added the simulators after. The simulators are 4 hole but the wheels are 7 hole steelies.
  9. I did mine in the past couple months. It wasn't as bad as I expected either. Did it with no help and was done in about 7 hours. That was removing the entire box from the cab, cleaning everything up and replaced both the heater core and a/c evap.
  10. I've often wondered what mine stickers for when new just out if curiosity mainly. Since I've bought my '01 Cummins I don't think I can be happy with anything else. With the low mileage I have on mine I should have it for quiet a while as long as I take care of her.
  11. That's me! I had a 1999 chevy suburban with the 5.7 vortec engine. My other truck at the time had the 5.7 tbi engine with 360k on it so I guess I expected the same from the vortec. Boy was I wrong. I had to change cylinder heads twice due to cracks, distributor went bad, and a few other little things here and there and I only owned it for 18 months. What a pile of crap. Then I bought my Cummins and didn't look back.
  12. I was thinking of doing the same, bed liner on the rockers just to help protect the from road debris. I'd like to remove my bed next year, I have some repairs to do on the gooseneck hitch and possibly the frame where it bolts onto it. Bed floor is gonna need some new sheet metal as well.
  13. That's the tricky part. The Cummins will last it's everything dodge did to the platform that will wear out. They're not in the business of building long haul trucks (in quotes) but with the Cummins engine you have the heart of a long hauler. I really enjoy my truck and hope to have it a very long time.
  14. Can I ask what you used to cut the old pieces out? Just curious, with the bed still on there isn't much room once you get around the corner of the cab. Also, are those the "slip on" cab corners you mentioned earlier in the thread? Looking good so far.
  15. On my android phone when you hit the button for the numbers the upper case key changes to =\> for symbols, hit that key and they come up.
  16. I agree @Tractorman, a "really cold day" is a matter of perspective. I am in the same mind set as you, 45° isn't real bad but you get down into the 20's it gets a bit chilly. Mainly I was thinking using this to warm up the cab faster at the beginning of the day or trip then just running like you normally would any other time.
  17. But with the a/c on in max position it would at least still help to remove excess moisture from the cab.
  18. I agree with @dripley, I've done the WT ground mod. After seeing for myself how these wires were spliced together by the factory it kinda made me sick. These trucks were not cheap when new nor are the newest 2021's and to see how they assemble some things is terrible. If nothing else and for no other reason do the WT mod just for piece of mind knowing it's done right. Just my $.02
  19. It's not a huge deal compared to some.other members here but I've reached 150,000 miles. I've only owned the truck for a little over a year. She had about 138k on the clock when I bought it but so far, no major problems and looking forward to the next several hundred thousand miles behind the wheel.
  20. And @Tractorman you are correct. Say your outside, have rain/snow on your clothes or shoes whatever. You will have fogging on the inside due to the excess moisture in the cab. I experienced this many times for one reason or another. Not going to dispute it. I was just thinking that on an exceptionally cold day, if the option was there it could be beneficial to at least get the cab warm then switch back to normal heating mode is all. With the controls in an '01 such as mine there is no clear way to do so, that's why I asked. @Tractorman
  21. @Tractorman, I see your reasoning here but, I have had vehicles in the past with no a/c from the factory. Yes, you would do best to crack a window to let the air flow better but you could still see. I do appreciate having a/c even in the winter for the defogging of inside of the glass for sure.
  22. Ok, so roughly a half gallon would do a truck. I saw that they sell the spray cans in a kit of 6 I think it was for the diy'er also.
  23. I tried it yesterday sitting in a parking lot as well. It seemed warmer, didn't have a thermometer with me at the time though. Idk, I was just curious.
  24. On the dash you can place the a/c on max and it recirculates the air in the cab to continuously cool the same air making the cab cooler in the summer heat. Is there a recirc setting that does the same for heat in the winter? Or do we have to set it on max a/c setting which blows the hot air from the main vents? Thought it might be useful on the really cold days.
