Doubletrouble
Staff
Everything posted by Doubletrouble
  1. So, as the title says, I had my first experience with the dreaded death wobble early this morning on my way home from work. I was on a rough city street that I've driven many times. Running about 40-45mph and hit a really rough patch then the front end went bat sh*t crazy. I tapped the brakes and slowed her down to about 20 and it stopped. Made it the rest of the way home with no issue. Been doing some searching as to the cause and it seems there are multiple reasons as to why it did this. Most seem to point to the trackbar and/or the bushing. I have checked the tierod end of the bar before and it seemed tight. I'll have to check again to be sure. Any other advise here? Anyone else have experience with a diagnosis?
  2. Yeah, you've explained that to me before. I just didn't understand how to set that up. I tried but failed 😔. Lol I'm not to computer savvy, I get by but some things still elude me.
  3. Those are some good savings over regular price. I should talk to my local napa store about an account. They have asked if I wanted one several times. Might take them up on it. We buy plenty of stuff for not just vehicles but we also have a small farm, several tractors and other equipment to maintain. Most if the tractors are antique and napa is pretty good about locating parts for them as well.
  4. I may need at tutorial on how to do a decent signature. I can't seem to figure it out I'd like to have a pic in it like mike, couldn't figure it out though
  5. I will check and clean the contacts and check voltage drop as well. I'm thinking that these relays are oem so probably wearing out but I also don't like replacing stuff that is good.
  6. @Mopar1973Man, do you think that the sycro failures, even though defective, would have lasted longer behind an engine with less hp/tq than what your putting out? Just curious. Also, to touch on the napa debate. I used to use autozone exclusively but their quality has gone to crap. Advance auto doesn't seem to be much better anymore. I tend to use napa when I need better more heavy duty parts and so far have had no issues. I've known several people that worked at stores other than napa that explained how the lifetime warranty works. The parts are cheap enough that they can afford to hand over 2 or 3 for free when they break. Replacement part quality has gone down hill in the years I've been wrenching. That's just my experience, not trying to provoke anything.
  7. Beautiful pics! I'm getting to the point though that I don't care for the cold so much.lol Checked my ac noise again with a different meter. I had .019-.023 fluctuation.
  8. So in preparation for winter I've been checking and testing some things to avoid issues in the cold. It has been cool enough for the grids to cycle so I thought I would test a bit to avoid later issues. I checked for voltage at the grid heaters in the intake horn. I had 10.33v DC. That didn't sound right, why not 12+ volts so I checked at the battery- 12.5 volts (engine not running). Checked at the hot side of both relays-12.5 volts. Then checked grid side of relays-10.33 volts. I'm going to assume this voltage drop at the relays is not normal or acceptable? Is this showing the contacts being worn and or cruddy inside the relay? Time to replace? Thanks.
  9. Nope, not in my case. I was very lucky, when I bought the truck it had a brand new set of 6 (dually) cooper tires on her. Didn't have more than 1000 miles on them, all factory size per door sticker. It may have had oversize tires before that, no way of me knowing.
  10. Yes it seems they are. In my case, running factory size tires, no major mods at all, I believe someone was in the computer and didn't know what they were doing.
  11. Mine had similar sediment as well. There was no pre pump filter. After doing some reading and investigation under the truck I found the fuel system was hacked together. I honestly don't know how it pulled fuel. The lines were if different sizes and just clamped tight together. I added a screen filer to catch bigger stuff pre pump. Fixed the lines so they seal and don't suck in air. Pressure was slightly better by 1-2psi so I feel in was needed. That's also when I decided a future big line upgrade should be done to promote better, more consistent fuel delivery.
  12. ***Final Update*** I had my buddy hook up to it again with his snap-on scanner. He found that the rear axle setting was on 9.5", the options were 9.5 and Dana. He set that to Dana since the truck has a Dana 80 rear and Dana 60 front axles. Tire size was checked again to be sure it stayed set on my tire size. By changing the axle setting it had changed the size again so he reset that to the proper size. All is good so far. I haven't driven it much, about 10 miles since this but as of now, no abs light and the speedo is now spot on compared to my Garmin gps. Glad that annoying light is off. Just wanted to post final results so it may help someone else in the future.
  13. So, his batteries are shot, starter? Hopefully it's an easy fix for ya so you can get your own truck up and running again.
  14. The meter I used auto ranges. I have another meter I will try. I also want to check voltage to the grid heaters to verify the relays are working properly. I don't like to wait for problems to pop up in cold weather. Rather test and repair before there is an issue.
  15. Yes it was running. I don't have a high end meter but I've used this one before when I did the WT ground mod and had a decent reading then. Thought maybe I forgot something this time. I'll have to try again I guess. I figured I should see setting, not all zeros.
  16. Finally was able to check for ac noise today. DVM black lead to passenger side batt. Neg. And red DVM lead on charge post of alt. I got .000
  17. Looks like there might be a poppet spring under the solenoid. Actually, looking at it again if you do not remove the oil relief plate the spring shouldn't come out.
  18. This may be extreme but could you loosen the body mounts on that side and jack it up? How much more room is needed to remove it?
  19. I will have to upgrade in steps as money permits. That being said, with a fass ddrp and 1/2" lines through the oem filter will this be a stable system? I don't know where my fuel pressure sits right now other than some testing in the drive way with a gauge. I will add gauges next year along with the fuel system upgrade. It's been a crazy year with this covid stuff so my income this year has been all over the place. Just going to work with what I have through winter and hope next year is better.
  20. Thanks @LorenS, that's a nice clean set up. What size lines did you use?
  21. The only requirements I'm aware of are that the relief valve on the vp44 is set at or about 14 psi to vent any pressure above that setting which then returns to the tank to carry heat generated by the vp44 away from the pump itself and also warm the fuel in the tank I would imagine. Anything dipping below 14psi and your barely supplying enough fuel to satisfy the vp44 let alone cool it down. That is my understanding of it at least. If I am wrong someone correct me. Now based on that if one were to upgrade to a big line set up, say from oem to 1/2" but running at the same pressure the volume would increase significantly but hopefully not so much so that your actually over supplying the vp44 which would put it at a constant relief valve open situation and in turn basically pressurizing the return lines I would think. Again, if I'm wrong, please correct me.
  22. Does the addition of 2cycle oil add enough lubricity to make up the difference stated above? Also, you run a double filter. Mine is a more factory setup with a fass ddrp. Technicality it should be moved to the frame to act more as a pusher pump rather than a suction pump. Will it function correctly if I move it to the frame and place some sort of filter between the tank and the lift pump and the still use the factory filter on the engine? I guess my concern would be a filter adding to much of a restriction between the tank and pump. Seems it would kind of cancel out the benefits of moving it to the frame. Is this thinking on track or way off?
