Everything posted by Texas CTD
That time of the year again
You were probably already at your axle rating so it's probably best that you didn't.
JOHNFAK WHERE ARE YOU ?
4BT will be fun. Your fuel pressure gauge is still alive and kickin'!
VP Longevity
Dang, I was hoping to see that thing hit 2 million.
VP Longevity
Dang he's changed a lot of VP's! Has he hit 2 million yet?
He's been on Cummins Forum a lot... And I've been wondering about 98whitelightnin.
DFI Injectors
Just get you a 7x.009 SAC injector, quite worrying about whether one is "25 HP" bigger than the other. From what I've heard, DFI makes a great injector (right up there with DAP and CPP) but they are a smaller company, and I've heard 1 or 2 complaints about slow shipping, but let me repeat, that's only 1 or 2 complaints. Most peope are very satisfied with them.
Life with the new 6 Speed Manual
You shift from 2nd to 4th, then to overdrive? Never seen anyone do that before?
dead pedal and hot weather
Not to go off-topic, but speaking of dead pedal, I finally installed a Timbo APPS today! No more dead pedal!
That's the Titanium version. They discountinued the Platinum series pumps. (single filter)
But Mike has what we call an "old school" Airdog 150. The new ones are junk - although a few people have good luck with them, I wouldn't risk spending $600 on a pump that is more than likely going to crap out. I recommend a FASS Titanium 150 GPH lift pump.
5.9 vs 6.7 exhaust manifold
Post #124 in that thread says it bolts directly onto a stock T3 manifold.
Made it to the mountains of VA :)
Ahem... VA has HILLS, not MOUNTAINS!
Not sure if this will have an answer to your question, but there's a ton of information here: http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/151365-he351-retrofit-second-gen.html
Crankcase Vent on 1998.5 Cummins
So that means all those parts listed (VP, ECM, etc) have been removed before... Interesting. There's a Chrysler sticker underneath the hood on our rig, and it's dated Feb. 1999, and it just says, "reflashed ECM." The truck was exactly a year old in Feb. '99.
Our '98.5 doesn't look anything like that. There's not even a vent there.
Got any pics?
And the blow by tube is where the vent exits, I guess you could say...
Hit a deer @ 60 mph
Check out Cummins Performance Parts.com.
CODE READER
http://bit.ly/1zpdWp0
We don't bale our own, but we buy round bales. We usually end up with 4x5 rolls, but we try to get the 5x6. 2 summers ago I helped a friend pick his hay up. There was 3 or 4 of us, and we hauled 1,400 bales from the field to the barn in 2 days. That was some work right there. It was the first week of August too... 100*- 102* outside.
What did you do before breakfast?
I usually eat breakfast first thing, so that means I was sleeping before breakfast. Starting at 6AM, I cleaned up the dozen or so oak trees I cut down at a lady's house a couple days ago. Did that til mid afternoon.
New Injectors
Not sure if it's true, but I read that you should use 5 or 6 hole injectors for 12 valves, and 6, 7, or 8 hole in the 24V, just because the cup in the piston is different?? Like I said, not sure if that's true or not. Maybe someone can explain.
Injectors and Turbo upgrade
MoparDave, '01 and '02 automatic trucks have the HY35. '98.5-'00 autmatics, and all standard trans trucks have the HX35. The HY35 has a 9cm exhaust housing, while the HX has a 12cm housing. The smaller housing means EGT's will climb faster when more fuel is thrown at the fire. Since you have a 47RE, that is what needs to be addressed first. Is it completely stock? If so, you're going to need to throw some money into so it will hold the power you're wanting to throw at it.
75hp injectors what size phatshaft?
Run those "75's" with your HX35, and control your EGT's with your programmer. What is your boost at WOT?
200000 miles
Ouch!!! You can get you a another truck with a good body for that price.
