Everything posted by Texas CTD
Nice Gift!
2 cycle Michael.
How Much?
Burned about 2 cords down here in SE TX.
JAG1 made it to my place.
That's a clean truck, JAG!
Throttle Stab
I've never stabbed it up to 2,500 RPM... Maybe 1,800-2,000, and it's smooth as can be. No hiccups or hesitation. Have you played with your programmers (changed settings, and/or turn them off) to see if it still does it?
will be busy soon, questions for the membership
I was scared to do it with the engine running, for a couple reasons. 1) metal shavings go through the turbine instead of coming out of the hole. 2) bit breaks off and runs through the turbine. I placed big magnets around the hole I was drilling, and that caught most of the shavings, along with a greased bit and tap. After I was done drilling and tapping, I used a shop vac and small magnet to clean up shavings.
DTT Assassin not pumping!
Good to hear. Whenever I swapped pulleys, it always changed my overall pressure, where either both (idle/WOT) were too high, or too low. But it depends on regulator spring tension as well.
Miss at all RPMs
Try a new set of lines? (new/used)
Lets see who you are!
I'll play: Older picture:
All 2nd gen truck pictures
It rode like a caddy.
- Almost 900K mile 24V
He shoulda pulled the 24V and stuck it in another truck, and kept going. I'm sure he didn't have time to do that though...- DTT Assassin not pumping!
Has your brother taken the back off the pump and inspected the inside? And to those wondering about the drill spinning fast enough, I've built up 10 PSI using a drill with the 16 pitch pulley on the pump.- draw straw 1
That's what I used when I installed my DS-I. Seemed to explain everything pretty well.- Comp Box with fass DRRP
Depends on which brand of injectors you get, and your driving style. I know there's been plenty of reports of almost smokeless 7x.009 and 7x.010 sticks. Ducky Fuel Injection and Cummins Performance Parts tend to be the cleanest.- 75hp injectors what size phatshaft?
Sorry I wasn't paying attention. '01 and '02 autos have the HY, so you have an HX.- 75hp injectors what size phatshaft?
HY35 can hit whatever boost you want it to hit if you throw enough fuel in the mix. Some people grenade their HY at nearly 60 PSI! Most people suggest no more than 30 PSI, because beyond that, you're just pushing hot air. 35 PSI isn't hurting anything though.- AFE Bladerunner turbo ?
If you want a 7x.010" stick, then run them on the stock turbo and see how you like them. Then you can decide on a new turbo, if you still need one after running the injectors on the stocker. http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/216421-injector-myth.html- Are you aware of the silent killer?
The very first time I went to the dentist, I had to have a root canal! I haven't been back since. I brush as good as I can with some Neem toothpaste, and use hydrogen peroxide.- Airdog quality
http://www.cumminsforum.com/forum/general-diesel-discussion/905914-please-beware-pureflow-products-including-airdog-raptor.html- blue smoke and rough starting
So are you "making" oil?- Artic Express Coming
We were in the upper 20's this morning. First time in a while we've gotten that cold this early in the season.- Little puff of white smoke when starting
It might be something that no one can repair......... Cold weather?- EGT Question
Yes, you need a turnbuckle for the HY35. Google it for some pictures. Getting a turnbuckle is definitely worth a try. I can hit 24 PSI with the HX35, completely stock with a pinched wastegate, and a minor boost leak. (no fueling mods, no boost fooling) Just don't push that HY past 30 PSI.- EGT Question
Wrong, sir... Stock 24V's came with a resonator and muffler. No CAT or DPF. Agreed, check the intercooler, and pay attention to the boost, so you can rule out a boost leak. When your EGT's spike, what gear are you in? How big are your "over-sized" tires?- Comp Box with fass DRRP
If the fuel pressure stays above 14 PSI at WOT, you're good to go. - Almost 900K mile 24V
