End Of An Awesome Era
- Replies 11
- Views 2.7k
Popular Days
You more than welcome to come hang around and even talk Chevy.
Well DW dont be a stranger at all. Always enjoyed your input and humor. I hope someone enjoys Mighty Whitey as much as you did. And by the way how much 2 stroke do you run in Chevy?
My wife cried when I sold my 02, she doesn't realize that it was just a hunk of iron, she thinks of it different than me she saw me pour sweat and passion into it for years but all things have an endi
Don't know quite how to type this delicately; so I'm just gonna type it..........
After a lot of soul searching and "hemming and hawing", I traded MightyWhitey and wound up buying a 2016 Chevy Silverado gasser. Really didn't want to, but I felt it was best both functionally and financially for me. Let me explain........
For the last year; I've been experiencing the P2121 etc. APPS codes on MightyWhitey. Got so bad that I took it to the dealer after setting the Smarty back to stock. New ECM solved it for a while...................but the variety of APPS codes have started popping up at random occasions and at the worst possible times. I cannot have that. Truck runs incredible until these codes pop; and then it's the dead pedal and/or hard fueling. I could never tow a trailer with this happening.
My parents are elderly, and I go down often to be with them and do stuff for them.................60 miles away. Cannot have a truck that tosses a code and is essentially undrivable .................especially in an emergency.
Also; I had the nagging thought of putting a fair amount of $$$$$ into her shortly.........................tires and brakes for sure; and then there was that nagging thing about injectors, front end work and clutch. 241,000 on OEM injectors, 100,000+ on the brakes, 170.000+ on ball joints and tie rod ends, 170,000 on the SB OFE clutch, etc.
Not to mention that the rockers were about ready to start showing holes in them from rust; as well as the rear wheel wells.
I'll still check in here, and spread my limited knowledge and BS around though.
I will be putting up my Smarty for sale here shortly also.
Thanks guys.
Edited by dorkweed
