Thank you. Your message about wiring a relay in the circuit for the lift pump saved my ecm. Yesterday I lost fuel pressure and the auto reset breaker got so hot it stuck in the on position. I couldn't hold it in my hand. I can't imagine what this would have done to the ECM. IMHO all should wire a relay in the circuit to the lift pump. Thanks again.
Edited by klcammie
  • Replies 57
  • Views 14.6k
  • 16 gauge wire will handle 20 amps up to 10'.  The relay should be at least twice the amp draw of the motor (20-40 amps).  If your fuel pump motor draw 10 amps at start up then the minimum relay will b
  • I've posted an article in the 24 valve 2ed generation fuel section titled "Installing Protective Lift Pump Relay". This should help explain why a relay is needed and how to install it.
  • SilverMoose
    SilverMoose
    @klcammie  I am by no means trying to hijack your thread as I got a relay installed for the LP yesterday.  It was a pretty straight forward task.  The longest part is making the wire harness to connec
Most all aftermarket fuel systems today have a trigger relay and 20 amp fuse. I would highly suggest relay and fuse protection to prevent the full load of the pump being placed on the ECM like OEM setup is.
Is there a Wiring diagram?  Where are you pulling power from ?
Most folk pull power from the battery.
+12V -> 20A Fuse -> Pin 30 on the Relay -> Pin 87 out to the lift pump
Black / White on the lift pump lead -> Pin 86 of the relay
White/yellow on the lift pump lead -> Pin 85 of the relay (trigger power).
2 hours ago, klcammie said:
Thank you
Your welcome, glade it helped.
Here's that diagram for anyone else that may need it.
is this only for aftermarket pumps that don't use the stock wire harness. I am using an airtex in stock location and just plug the pigtail into the pump?
The pig tail for oe pump pulls the power thru the ECM. Hooking it up thru a relay takes the load off of the ECM. The aftermarket pumps that come with a relay and harness are designed to use the oe pigtail for a trigger wire and power comes from the battery and not thru the ECM.  That being said if you are connected to the oe pigtail straight to your pump you are pulling the power thru the ECM.
Is the relay in your drawing a separate relay, or are those the numbers from the   Relay box under the hood?
I also have a pump made for stock location and Air Dog says to just plug and play. Maybe I will change it .
relays have a standard number to show what pin.  30 87 86 85 are printed on the bottom of the pin.
At least I thnk thats what you are asking.:think:
Edited by Me78569
Your airdog 150 should have came with wiring harness and the relay, and part of air dog harness plugs into truck hardness if it was updated at Dodge dealer to have a lift pump mounted to the engine instead of fuel basket. Or it might be the other way around, either way air dog and fass as far as I know both come with wiring harness with a relay included. You might just need to find a wire that comes from ECM to power that relay.
Edited by Dieselfuture
This is a typical automotive relay you can buy at any auto supply store.589cf003d48b2_5-pin-automotive-type-12volt-40-amp-relay-with-diode-protection-alt-ry18-3-2542-p1.jpg.478e888b891f55623e725f1f7ed6a7ba.jpg
Do not use pin 87a.
I've had some relay terminals marked 1, 2, 3 and 4.
terminal 1 = 86
terminal 2 = 85
terminal 3 = 30
terminal 4 = 87
The yellow/white wire comes from the ECM and was uses to power the stock fuel pump.  This is the wire you want to trigger the new fuel pump relay at pin 86.
My lift pump is in the OE position. I used Ibmobile wiring.
Edited by klcammie
Correction
I've got the FASS ddrp that uses the factory connection.  I keep thinking I should add a relay and this post confirms that.  Oil change & relay this weekend.
L8tr
D
The Air Dog harness has the ECM plug on it just like the factory plug and set up to only activate the relay. I think FASS does also.
Sorry for the dumb questions but I will admit I am electrical challenged. the advantage to this is it takes the load off the ecm. so have many people had problems with this and this was best solution. Just trying to see what advantage this has over factory- can the factory ecm not handle the load?
Also where are yall mounting all this for a stock pump location on engine.?
I have learned a lot on this site in the last month or so and just trying to do what is best for the longevity of my truck.
Edited by 2001cummins
add
Basically there is no protection relay or fuse between the lift pump and the ECM. So if for some reason the lift pump to lock up or short out the ECM would take the damage and cost upwards of $1,500 and higher to replace. So protection relay and fuse is much cheaper than losing a ECM.
thank you sir, that explains good enough to me to justify doing.
one more question
So the yellow/black wire- IS this one that is on the stock pig tail color-that connects to pump?
Black/White wire- IS this one that is on the stock pig tail that connects to pump?     - These two can just be cut and then wire to relay box?
then 87 you have going to fuel pump. will this be just the red wire off my lift pump  and then ground the black wire on the fuel pump somewhere?
edit
thanks, Sorry guys for all this. I am mechanical on trucks, but electrical on anything i just want to make sure.
1. So for my number 85 can i hook both my lift pump black wire to it also along with the ground wire that is coming from the ecu?
2 Where did yall mount the relay so it was out of the way and none of the wires can come unplugged?
3. 20 amp fuse is good?
