Got ya,  I checked at mccall and it was 38xx.
regardless the altitude has a big effect on smoke vs fuel at 0 psi.      I THINK the ecm does something around the 2000' altitude area in the maps.    I always  noticed a big change in north platte - grand island area in terms of smoke reduction that is abrupt.
Edited by Me78569
Ill look when I'm around my tuning computer.
I'm going to say around 80% is your starting point.
Thanks, I'm at 86 now with 75hp so I was guessing 80 for 150hp I'll have to see what it does on my current tune and go from there.
BTW when are you planning on doing 7x10, I know you've been mentioning it latly. Are going with vco and about 320 pop? That's what I asked dap for, should have them in few days.
3 hours ago, Silverdodge said:
@Mopar1973Man 90 percent
I'm guessing because of 14mm housing and being automatic you can start higher. But then like you said earlier you want more on take off.
Yep I want that turbo to spool
On 8/8/2018 at 10:46 PM, Dieselfuture said:
I've been kinda following your foot steps on turbo and now injectors, I just got a set coming of 7x10 vco at 320 pop. Hopefully my hybrid 62/67/12 won't run too hot. I know I can tune it out and maybe won't need wiretap at all as I hardly ever used it before. Where do you start your canbus at, I know you got auto but just curious.
Will someone please explain why the 320 pop instead of a higher pop off number, like per say for example 400 on the injectors. If I remember the lower the PSI pop the worse atomization is and it doesn't burn the fuel efficiently. which leads to poor performance and mileage. So if I am guessing the higher the numbers in bar the more advanced the timing is??
Thanks!
Thanks!
Here ya go
https://mopar1973man.com/topic/13364-testing-injector-pop-pressure-in-the-real-world/?tab=comments#comment-168059
