High Idle Kit Is Here
Things that make you go hummm?
I live 60 miles from DieselAutoPower and am wondering if they would only bill me $45.00 to tune in the parking lot.  I guess I'll call them tomorrow and find out.  I need to set my tire height also as I'm 6 mph off according to the charts.
Question to the board:
Even in warm weather my grid heater cycles every few seconds.  I have removed the IAT sensor to clean, but it was spotless as I have no exhaust brake. Should I replace the sensor, as I had to replace the MAP sensor a few years back?  I get tired of that annoying click and light dimming when the heater cycles off and on.
Unfortunately, IIRC, you will not be able to recalibrate your speedo for your tire size. Because of the catcher software, once you remove the smarty, your settings go back to stock. When you load a smarty onto a vehicle, the smarty "disables" itself and it can not be perpetually used to load onto other vehicles until the original is put back to stock.
Guest
This topic is now closed to further replies.
