Cruise Control Light
- Replies 29
- Views 15.1k
dripley 8 posts
trailhead 6 posts
Mopar1973Man 5 posts
Evan 2 posts
I think finding a new will be difficult and very expensive. I would want to know more about their 1500 dollar one before purchasing. It may be possible to reprogram the ECM you have but I dont know t
When I went thru my debacle with a rebuilt ECM, I kept the second one even though the cruise light was constantly illuminated and the cruise did not work. When that one died a year later the light was
I had the same issue with a rebuilt ECM back in 09. The first one was bad but the second one worked, all but the cruise. The light was illuminated constant but ctuise did not work. The problem did not
My cruise control light was always staying on, but the fly-by-wire cruise didn't work. After much problem solving, I finally took the 2001.5 Ram 2500 6 speed diesel to the dealer. Trust me, it wasn't my first choice. Anyway, they told me that the PCM didn't know that I ever had a cruise control equipped truck. The tech claimed that part of the PCM hard drive was dead.
The dealership ordered a PCM, but somewhere along the line there was a mistake and they received a PCM for an automatic transmission. They didn't install it. Instead, I ordered a PCM from NAPA for about $450. The PCM came in and the dealership agreed to install it, labor free, since they'd screwed up so many times previously. So, they installed it. Then I got a call saying they still couldn't get the cruise to respond and had determined it was the instrument cluster. Cha-ching! The dealership tells me they can get a new cluster for $790 plus core deposit. I decided I'd buy from O'Reilly who wanted $330 plus core deposit. Well, it was supposed to take a month to get the part from O'Reilly. Nope. A month later they can't get the part, and they tell me that they might be able to get it if I wait another 4 months. So, I gave up and told the dealership to order their $790 dollar part. Three days later (yesterday) they get the part and try to install it. Tech calls me up, "The part that came in is Canadian, and I can't install a Canadian cluster into your Dodge." I assume it was due to KMH instead of MPH. Anyway, I've had it at this point, so I told the guy I just wanted my truck back, and that I will never be back. Guy ordered (or coincidentally received) the wrong PCM AND the wrong cluster. He seems entirely incompetent. After 3 months and almost $1000 nothing has changed on my truck, the cruise light is still on (always) and doesn't work! In case you're wondering, the cluster does not throw any codes when tested.
I wish I wasn't so dense in this area. Can the cluster really be the issue? Can I get one from a junkyard? Should I keep trying to find a new one somewhere, or can someone just fix the one that I have? Should I put pressure on the dealership to get back some of the money I squandered with them? Thanks for all of the advice!
