- Replies 22
- Views 5.9k
Mopar1973Man 4 posts
KATOOM 4 posts
Cowboy 4 posts
Me78569 3 posts
In stock form, you really don't have to worry about EGT's a whole lot on a healthy system. Cummins gave out the 1250°F number, first we know that there is padding there, second, that's only a problem
I agree with that... Just small upgrades like mention above will make a huge improvement in towing power without killing the transmission quickly. Don't get me wrong but the 47Re transmission is the w
He's already got one, unless you're referring to the VP.
Rookie post even though we've own this thing since 2005. Often herd there are no dumb questions, well here is one
Our Trailer and stuff in bed of pick up is about 12,000 pds loaded. 2001 truck is stock with 47re with a 4:10 rear end. When going up long mountain grades, I make it point to not go over 1150-1200 on my pyro. On long upgrades I usually end up falling in line with the big trucks and just chug up to the top about the same speed. But not unusual to be passed by other people pulling about the same weight, sometimes like I'm standing still. I understand newer equipment has bigger horsepower. I don't care if I'm not the first one to the top of hill or not. But wonder where some guys, some in 2nd gens get their power from? I do admit getting a good run at bottom of 65 0r 70mph hill helps a bit. I usually have O/D on at start of hill and then take it out of O/D as speed and rpm starts to fall off. I’ve tried the “drive with O/D off when pulling weight”. Sure get tired of the noise by the end of day, running 2100 or 2200 rpm all day long. For MPG folks…We can get around 12 mpg with O/D on and with O/D off at 2100 or 2200 all day long MPG goes down to about 9. Not that I worry about MPG that much, but sure do hate the noise all day long.
Might seem laughable to some…I’m a retired truck driver. Was a lot easier going up long upgrades in big trucks with a manual. Just find a hole to keep near top of power curve, drop a hole if rpm’s falling off to much.
So I’m wondering if I shouldn’t push it a bit harder?
Or maybe I should ask… How do you tackle mountain grades or what other power do I need.
Edited by 015point9
