- Replies 14
- Views 3.1k
notlimah 4 posts
Mopar1973Man 2 posts
JAG1 2 posts
015point9 2 posts
Op here...and not a very experienced OP Agree 100% Operator error on my part! After getting gauge and new fittings from Vulcan I wasn't sure of best way to have portable gauge hooked up and
If I were you and had the whole thing apart already and the money to do it, I'd make sure all my lines were 1/2in just to be done with it and never have to worry again. I'd also go with a Liberty modu
Op here... maybe wrong but I'm planning on leaving my fuel strainer intact. My basket worked many years with return line dumping into it. My thinking is enough fuel is getting into basket to keep
Currently have all fuel lines removed from fuel tank to VP44. The lines that are inside the fuel module are 3/8 in size (about 8 inches worth)? All other lines to VP44 are ½ inch. So just the line inside the fuel module are 3/8.
Before I took the Air dog pump off , was at 21psi at idle using Vulcan pressure gauge. Unsure about fuel PSI in actual use, just at idle, before I took it apart . (Also going to install pressure gauge)
How much do you think or guess a 8 inches of 3/8 line inside fuel module will affect PSI at VP44.
The reason I don't want to change out smaller fitting now is because the fitting in top on module has been glued in and don't want to take chance of breaking the thing.
Edited by 015point9
