- Replies 36
- Views 7.6k
gassernomore 13 posts
Dieselfuture 7 posts
Mopar1973Man 4 posts
Haggar 4 posts
After replacing the vacuum line connectors, went thru and made sure I didn't cross the red and black lines somewhere. Didn't. Checked for vacuum at the switch, good. Checked vacuum at the first connec
If transfer case shifts and front shat locks, could be a cad. Something I just fixed on mine. It's more likely something to do with cad as the light for dash gets tripped when pin that ho
So what? At least my 4WD works all the time on the 2002 where the 1996 might not work when you really need it.
My 4 wd is not engaging. I have tried searching with no luck. Must not be entering the right words. The dash light does not come on. My mind has drawn a complete blank on what to look for! I know it is something simple! Thanks
