Advice before purchase
- Replies 34
- Views 6.6k
JAG1 6 posts
JasonT1977 6 posts
Dieselfuture 4 posts
kzimmer 4 posts
Popular Days
@Mopar1973Man how could you, and not let us know, and why so cheap ...
Take your time, have it checked out by someone that is well knowledgeable about that year and model truck. Just because a guy has tools and is breathing doesn't make him a mechanic much less qualifie
I tow with a basically stock 01 shortbed Dana 70, I gross just under 20k with all hooked up About 9500 lb on camper fully loaded, around 7500 on truck and and 2500 on boat. I have pretty much the bare
Hello All,
So I am in the market for a truck. I owned a 2002 6 speed a few years ago. I'm looking to get something similar. I would like to get newer but I am limited on budget.
I was wondering if you guys could give me some advice on how heavy a camper a 2002 4x4 6 speed could comfortably pull.
I guess I'm looking for a general rule of thumb- If I get a camper that is over 10,000#, do I need a dully?
If I stay between 8 and 10,000# can I safely pull and stop without adding brake controllers and the lot.
I like to keep things pretty simple, I just wanted to be educated before I begin my search for truck and camper.
My goal is to have a stock truck, preferably not a dully, can add a 5th wheel if need be- but just want to stay in comfortable parameters without a lot of hassle.
On a side note- my camper will pretty much be stationary- maybe occasionally pulled around.
Thanks for any advice you can give me.
Jason
