High amp alternator
The truck I just got is on its 3rd alternator in a couple years according to previous owner, all have had diode failures causing the TC lock/unlock condition. Assuming that a quality high amp alternator is going to last longer than a over the counter replacement unit..
I was looking at nations alternators but the one for the 24v diesel looks to have a 2 pin plug on the back of it but mine has 2 ring terminal studs. Im new to dodge and cummins. What am I missing here? Does the 98 24v have one off parts or something??
  • Replies 217
  • Views 57.7k
  • Mike is correct...the large current load on these 3 phase hairpin stators in conditions where all the available current is delivered does tax the design of the factory alternators. The diode's are all
  • I must admit there are many keen minds pondering this subject matter and I'm almost afraid to continue on this path but, nothing worth while is easy.   BTW...I'm still working so, when you n
  • @Dieselfuture Yes Sir, you are correct, multi pin weather-boot connectors should be dressed with Electronic Grade Silicon grease. It's a clean product and benefits small signal or low voltage contact
2 hours ago, notlimah said:
@W-T Link to the batteries you’re using??
@notlimahThe AGM's I'm using are Optima but, there are other band names available. The Red Top Optima is what I selected because of the cost factor. The real "high end" AGM's featured in the audio world are extremely robust and investment at that level was beyond my requirements. My primary reason for AGM is only to avoid the slow lingering corrosive out-gassing that is prevalent with wet lead acid packages. AMG's gas too but, at extremely low levels and if you experience profuse gassing from an AGM package there is real issues in the charging system.
@outlaw7 would have experience with AGM plaftorm selection due to his background in high-current,demand, audio systems.
Oh... and yes Garet...wow...your efforts and extreme fortitude in that project is off the hook ! Perhaps I missed it but, I must ask ?...did you address the "ground" regarding the four blk/tan wires "glue spliced" in the harness at the front of the engine? This is the ground lead (#8 blk/tan) that is connected to the passenger side battery tray. I'm very concerned about that particular aspect. The method Dodge implemented with this ground assembly and routing, is in my opinion, a real error.
@dripley  this "ground" assembly I'm referring to is something you should look at...you're going to truly dislike the procedure if you elect to do so but, knowing about your long term telemetry observations I think it would be prudent to invest the effort.
I'm going back out in the garage to continue with this project...@outlaw7 is out pacing me by miles.
This thread has been extremely interesting. I looked up the Caig DEOXIT that W-T mentioned. It is available in several different configurations on Amazon.
2 hours ago, outlaw7 said:
.... and two again whilst bewildered scared and alone I found a true nugget that might save my sorry ***. guy claimed to have same symptoms I do werird codes no pcm coms no buss and dead pedaling issues that act strange he was checking connections and found his power distribution block harness connector ( the one that ties the engine harness to the firewall and power etc ) was NOT ONLY LOSE BUT NASTY HER CLEANED IT UP AND TIGHTENED IT AND BYE BYE CODES AND PROBLEMS ...WELL JUST SO HAPPENS WHEN I WENT TO YANK MINE OFF THE DAM BOLT SPUN FREELY IN MY FINGERS sorry caps lock bomb....
Are you talking about the bolt that holds the power lead terminal to the power distribution box? Sorry, having trouble knowing where this is...
I am thinking he means the one in the upper right corner in this picture.
I hope no one cringes at my dusty under hood but I am normally parked in a dusty world at work most of the time. Not that anyone here is anal about cleanliness.
Edited by dripley
You are welcome. Now if some one had one photo that would make me electrically UN challenged, that would fantastic.
I understand. The first thing that's taking a long time to sink in is the ground, being that 'it goes to ground' and is called negative, actually the electrons are running the other way, from negative battery post to the positive. That one messes with me real good like the earths coordinces got switched somehow.:whistle2:
That's OK though.........Cause I've read this thread many times and has helped a lot.
But most of all W-T has taken the time to talk with me on my level / used a concrete drill to get things thru my thick head
Dripley its most important to ask questions on whats got you baffled. Not asking is not smart because now that W-T has drilled it into my thinking it has become very simple. I can't explain how it feels to have all this discomfort and confusion about it for so long and then all of a sudden like being cured from a disease, be able to understand.
I understand what you are saying and I have read this with great interest. Need to do some re reading to get a better grip on it. My problem right now is no time implement any help I would get. When I get this darn CFA open I will be back on an even keel  and have some quality time to digest it better. Think I will retain the info better and fix my gremlins.
@W-T I agree with what you said above. I have a  spare engine harness I partially opened up the other day to find that ground. I am hoping to open up, address any issues and swap into my truck.
I think the older we get the more important, for staying young, that we learn things and stay interested. W-T has woke me up from long sleep :thumb1: and know how dormant I was before.
I've been trying to keep up on this thread. Wish I could contribute more to the research but I'm busier than a one armed paperhanger.  There are a lot of promising things being found and discussed.  It will be interesting what the finale findings are.
9 hours ago, Dieselfuture said:
That is a bit disturbing @IBMobile :stuned:
Especially for those of us whose relationship with electricity is akin to hot grease and skin.
Absolutely fantastic thread guys!!!!!
Keep it up!!
 Ok Dripley n Jag1 yes that was is the bolt and connector I'm talking about in the pic upper right corner black connector and W-T yes I fixed all of them there were 3 places the ground did that I'll be reinstalling today
I'm going to open a web store selling cable kits custom harnesses test tools and DC filters stiffining solutions soon
 That's what happened when Dripley tried wiring up his hood ornament to have open wings at 60.
After rereading some of the earlier posts I thought that I should chime in. When I started working back in the 70s electrical and electronic part were made for X power but were heavy enough to almost double that before you worried about it. As time has gone on the over power capability has gone down. This is why I think that a original alternator would go so long and the rebuilds (using new parts ) don't last. I worked as a R&D tech and was allowed to do things (destructive testing) that would get a person fired today. As time has gone by I have noticed that this has happened to all aspects of my life and that to many things that I deal with. If you look in a UGLYs reference you will find that almost all of our harness wires are under sized for the current vs run.  A good example is we would put a v8 in Toyota with the stock rear end and not break it. Today you can over stress a rear end just by putting a tuner on one.
Edited by Nekkedbob
These new vehicles are being made as light as possible to meet the federal Corporate Average Fuel Standards (CAFE), still conform to the National Transportation Safety Board (NTSB) requirements, reduce tail pipe emissions for the Environmental Protection Agency (EPA) and make a profit.
With computer aided designs the tolerances can be taken down to where the fudge factor is engineered to the minimum allowed.   The weight reduction in just the wiring harness has been reduced.  The pre 1990 autos had heaver gauge wire in them IE: 16 AWG used for the park, stop, turn lights now there is 18 AWG and some systems, CVVT solenoid comes to mind, are using 20 AWG.  Plastic bumpers, plastic doors, plastic fenders and plastic junk.
Where lucky these trucks have made it this long.  With bad EPA solder, ground wires just jammed together with out even a crimp.  Auto trans that can't take the torque of a diesel engine, OEM lift pumps that fail every 15,000 miles, dashboards that crack into 50 pieces, et cetera.    With out web sites like this and some decent aftermarket parts these trucks would have ben in the bone yard years ago.
                                         5a812bc6ac741_animated-smileys-speech-balloons-1121.gif.b11cbea6234bd16d26d1967210308a07.gif
Trucks probably,  drivetrain,.... not all. I'm speaking off an engine, manual transmission, Dana axles,  NP transfer case, pretty much why I bought my truck. There seems to always be enough enthusiasts to keep things going, if our trucks were made much cheaper there would have been a lot of other vehicles without a drivetrain in them,  just thinking out loud here.
Edited by Dieselfuture
Smart phone is not too smart
I can see the day that we junk vehicles just because the electronics are shot and are too expensive to repair. Chasinf gremlins at a shop is already expensive.
If you have access to Sam's Club, they sell about the best batteries you can buy. The Duracell line are rebranded Dekka/East Penn batteries, the only ones left that are still make 100% in the USA, from smelting to finishing. I shoved a group 10 AGM in mine, it has 800CCA/1000CA and 210 min RC. RC is how long it can supply 25A of power (average vehicle draw) before dying. So my single battery can supply 300W of power for over 3h. It doesn't fit quite perfect  in the battery box but it's in there ;-)
