No traction on the boat ramp! What!?!
- Replies 19
- Views 3.3k
Mopar1973Man 5 posts
SavageTusk 3 posts
notlimah 2 posts
Ben 2 posts
You might want to check your trailer for adjustments to move the front of jet ski closer to the ball hitch, adding more weight to the axle.
Makes no sense. He’s talking about traction. Wider the tire, more rubber on the ground, more traction there will be. If what youre saying applied to this, formula 1 cars would drive aroun
Well today I was pulling a .. Ahem.. JETSKI out of the lake and for the life of me I could not gain traction. Pretty rediculous. Finally I used the ebrake trick to ease it out. Cmon though, a jetski! Anyway my truck performance add-ons are listed below. My question is, you think just tires are my problem? If so what are some good tires I can put on my 16" stock wheels? Or, if tires aren't it, other suggestions?
Current - LT245/75R16 120/116s
1999 dodge ram 2500 5.9l Turbo diesel
- Quadzilla Adrenaline Programmer
- iQuad Bluetooth Guage display
- hx35w turbo
- boost elbow
- Pusher 24V2G Aluminum Intake Manifold
- S&B Cold Air Intake
- Air dog 150gph lift pump
- 1/2" big line fuel kit
- GM Transmission Governor Pressure solenoid conversion
- 4" turbo back exhaust with 4-7" tip
