47RE Transmission - Want to service&install drain plug
- Replies 18
- Views 7.5k
Add-on drain plugs are notorious for leaking as they age. I would strongly consider a deep aluminum pan as an upgrade. You get extra fluid capacity and a drain plug, but the biggest benefi
I use them all the time. It's a good, well built and well machined pan...and made in the good ol' USA. I bundle them with all of my builds now.
In this case you might have been better off not following or not having an owners manual. What I do is change trans fluid every 30,000 miles and when checking your trans level give it a smell,
Want to service my 47RE Auto Transmission and install a drain plug on the pan.
B&M advertises a plug, but I have read they can/will leak.
Are there any other options for a retrofit plug?
If someone has done this job, what is the best location for the plug?
Also, if there is Go-By article, would someone please point me to it?
Thanks.
Leaky
