Performance Upgrades
- Replies 78
- Views 22.5k
Imaybail 17 posts
dieselautopower 10 posts
gipperkid 10 posts
Dieselfuture 8 posts
no need to do anything with the injectors. 309 is the pop off pressure. You will like the extra power!
HX35 can have either option below 5 bolt hx35 https://www.dieselautopower.com/s200gx-e-dodge-ram-upgrade-turbo-12769880001 picture #2 hy35 is same as this https://www.dieselautopower
Your Super B will get you to your desired power range, when coupled with the Adrenaline and 7 x 0.009 injectors or larger.
So having owned my ‘99 for a little over two months and towing my tractor a few times I think I have decided to see if I can upgrade some things to get some more power. I am as I think that would satisfy my needs.
Looking at 7X.009 SAC injectors, a turbo, gauges, and a tuner of some kind to manage smoke and heat.
Need some recommendations on a turbo and tuner.
Thinking about this Turbo as a direct replacement.
For the tuner: either an Edge Comp or the Quadzilla Iquad. Really don’t have the experience to create my own tunes and need more knowledge of diesel theory to be able to get the most out of a tuner so leaning towards something with “canned” tunes.
Will run gauges for egt, boost, and trans temp. What range boost gauge should I use, up to 50psi? Already have a fuel gauge.
So chime in guys with your ideas and help me choose the right parts to start with.
