- Replies 33
- Views 13.9k
Mopar1973Man 11 posts
98whitelightnin 4 posts
pepsi71ocean 3 posts
IBMobile 3 posts
maybe it is just me, but my sport with bulb upgrades is fine. i have newer vehicles with projectors and yes they have farther, brighter output....but never have i felt like my sport was in
Most likely will happen. 100w bulbs pull about 14.2 amps. You would be best setting up relay kits to keep the wattage off the stock wiring. The other thing to watch for is the amount of heat the bulbs
From Daniel Stern Lighting a couple of years ago, The best 9007 bulbs presently on the market are the GE Night Hawk Xenon 9007NHX or the Philips Xtreme Vision 9007XVS2 The be
It it possible to wire in a 9007 pigtail to the oem wiring to obtain brighter light? i believe theyre is somewhere in the range of an added 700 lumens when swapping from 9004 to 9007. Seems it could be a worthwhile upgrade for those of us that cant afford a projector retrofit or fancy leds.
