How well does your truck pull 8,000 pounds
- Replies 73
- Views 13.5k
pepsi71ocean 16 posts
IBMobile 8 posts
Mopar1973Man 7 posts
Ben 7 posts
I also have the EZ and the RV275's but with a 4:10 and 245/75-16 with a 47RE. My 5th wheel trailer is 8k and some times I put about another 600 pounds behind that with a 14' boat, motor, gear and tra
Every valve body I build (47RE or 48RE) will lock in any forward gear (with external switch) and allow both locked 3-4 upshifts and locked 4-3 downshifts. There is a signal that needs to b
I absolutely love the towing power. If there was anything I could change it would be gearing...or should I say, the lack there of. I would love to have at least a couple more gears. Or something li
I pulled an 18 foot trailer with 2 razors and other miscellaneous stuff today on a 80% highway about an hour each way. I was running 70-75 most of the time. Until the hills if they were 6 or 7% grade I would lose speed sometimes down to 60mph. Now if I pushed the go pedal nothing happened untill it kicked down and was screaming and starting to haul a$$. Now my brothers 99 with a built trans, 100 horse injectors and an edge ez. Don't have this issue. He just mashes a little and rolls on. Is it normal or something a tuner could help? Or am I asking for more than I should be? I ain't saying it was horrible just that it started to lose speed when I didn't expect it to. No loss of power or dead pedal just not picking up speed. Sorry for the long post.
Edited by Unreal Summit
