New dodge owner in need of help!
- Replies 17
- Views 5.7k
Kane4sythe 4 posts
Mad Bomber 3 posts
pepsi71ocean 2 posts
Me78569 2 posts
I would drop the Torque converter cover and look for an after market converter. Then do the same in the valve body. There are Pan off upgrades that could be done, if they are done it mi
Really the entire front end suspension should be gone through. Steering, control arms, ball joints, track bar. Anything between the tires and the frame. Pull the pan off and check for
Welcome, you pick the right truck to learn on, you'll have lots of experiences. Like mentioned above don't try to fix everything at once, some of it may not need to be fixed, other times you fix more
First of all, I hope this is the right category and I do all of this right, this is my first time on this website. I have recently bought a 2001 24 valve with 193000 miles on it. The dealer that I bought it from did not have any decrcription if the truck other than that it was a clean truck. I am completely uneducated in diesel trucks and honestly mechanics in general. This is my first diesel truck and my first vehicle in general. the truck is an automatic, and although I’ve hear manuals are more fun, more reliable, and all around better tranny’s, an automatic was the only one that I could find that didn’t cost an arm and a leg, wasn’t rusted out, and didn’t have tons of miles. From what I can see on the truck the truck has an RP-4G-100 pure flow airdog, a new transmission pan, gauges, and an edge comp box. I have been led to believe that the comp box has not been wired correctly to the fuel pump due to most people having the result of black smoke especially when on level five, but I have not even seen a puff. Basically, I want to make this truck a reliable daily driver, with the hopes of adding some horsepower later on. What should I do in order to make this truck reliable? I have been suggested a shift kit and torque converter from another forum. By the way, the truck also shifts sort of rough between 3 and 4 gear sometimes. This does not bother me, but if it is a problem I would like to address it before it worsens. So basically, how can I make my 2500 with the plagued 47re up and running for the long run?
thank you fo any help.
