- Replies 15
- Views 10.4k
JAG1 5 posts
Mopar1973Man 4 posts
Evan 2 posts
IBMobile 1 post
Popular Days
All the products I've used typically already comes as a pre-measured dose. Unless you happen to use gear oil with the additive already.
I use Cat friction modifier and add a bit then run it. I add more if it's still chirping, mine does need a little more but it is 100% better than with none. Thing to remember is if you're not usi
I put tractor transmission fluid in everything. That's what's in my entire truck well not the motor or brakes. Not sure what's in the power steering It's made for heavy duty wet clutches.
Hi,
I have a DANA 80 with Limited Slip Differential that I’m draining/changing fluid in.
How many oz. of additive do I need for a complete oil change please?
Thanks Leaky
