Upgrades to 2000 2500 for towing
I've got a new to me 2000 2500 2WD Regular cab with NV4500 transmission and I believe the HX turbo (rubber wastegate tube). 190k miles and no idea how many miles on or even what injectors it has. I'm looking into upgrades to improve towing performance with a 14000lb trailer (20k GVW). I'm not looking to have huge HP or Torque, just to have a decently powerful, reliable and efficient rig. I definitely don't want to upgrade stuff and push it beyond its limits.
I don't currently have a EGT sensor. I know I need one.
I've already put on the GDP mechanical fuel pump so hopefully I won't have to worry about the VP44 dying for lack of pressure. Running 2 stroke with every fill-up.
I live in Colorado and have a 35% opacity limit on smoke coming out my tailpipe.
From what I've read I should just do what MoparMan himself has done and get 7 x 0.10 injectors and a Quad V2. I'm concerned about emissions if I have to remove the Quad to get it tested. I'd rather not tap the VP44.
  • SAC or VCO?
  • How bad is the smoke on 7 x .10s without the Quad?
  • If I clamp the waste gate (and maybe use a boost fooler) will that solve smoke issues of running without the Quad for opacity inspection?
  • Do I definitely have to upgrade the clutch?
  • Do I definitely have to get ARP headstuds installed? Can I put in headstuds without a new head gasket?
How well do RV275s work for towing without a chip? Would I still have to upgrade the clutch? Do RV275s need a boost elbow and fooler to get enough air?
Anybody do a death wobble steering stabilizer mod?
The articles section is great on this site but it sure would be cool if there was a "list of stuff that works together" page that collated some of the great info floating around in the forums.
Thanks for the help,
Justin
  • Replies 64
  • Views 17.9k
    It's only taken me 17 years to get that far...  Quadzilla +150 HP VCO Injectors (7 x 0.010 @ 320 bar) 425 ARP head studs Exhaust brake 4" Exhaust  South Bend
  • For the money spent and the lack of necessary supporting mods, I would go with an Edge EZ and RV injectors. The EZ does the boost fooling and comes with a boost elbow for the wastegate hose. The RV's
  • Ez and rv275's should pass emissions without trouble.       Gonna be ~300hp which is plenty for towing.  Def need a boost elbow
7 x .0085's are about the limit without tuning to pass smog at altitude.
7 x .010's with v2, is a great setup even if you dont tap the pump.  It will run stronger, cleaner and cooler than just running 7 x .0085's without tuning.
That would be my recommendation.
Leave the quad plugged in they dont check under the hood here in co only lug down test.
Given the altitude you really need tuning if you are pulling any passes.  Any extra fuel really spikes egts.
Clutch is a good idea.
Edited by Me78569
Thanks for the info. I'm only at 5000' up north of Denver.
Questions I forgot:
Who has a decent price on all of this?
Do some vendors have better injectors than others?
Anybody currently running this kind of upgrade on a stock clutch?
Thanks
Diesel Auto Power is who makes the quad and they supposed to have good injectors too. You can put in head studs 1 at a time with no problems.
Is there any reason to get new injector bodies vs reman?
Has anyone just kept the bodies and replaced the nozzles?
@Mopar1973Man, did you have any issues with your clutch after using the Quad or upgraded injectors? I'm not super excited about doing a clutch upgrade.
Thanks
Are there any new injector bodies.  I think what they call knew are all remanded Bosch bodies
All mechanical injectors,  turbo, boost fooler. Smarty only for half power to pass emmisions
Clutch when needed
Already running South Bend ConOFE clutch. Stock clutch barely held the Edge comp back in the day with stock injectors.
https://mopar1973man.com/garage/vehicle/101-2002-dodge-ram-2500/?show=mods
Another reason why I opted for the 245's tire the smaller tires tend to break free early and easy which saves the clutch and driveline from damage.
Driving characteristics personality and attitude seem to have more to do with clutch life and slipping than tire size
For the money spent and the lack of necessary supporting mods, I would go with an Edge EZ and RV injectors. The EZ does the boost fooling and comes with a boost elbow for the wastegate hose. The RV's are new Bosch, so most vendors don't require a core.
I used this combo for 12 years on my '01. OEM clutch, lift pump and turbo. It dynode  335 hp. 300k miles later, I am still running the RV injectors, 4 years on the Edge Juice.
While not at altitude my current setup is a beast towing in the mountains of PA.
I think 100's are a great set up but there are guys who live in the mountains who can give you better advice.
DAP injector are great, IMO get them popped slightly higher, or pull them and get them popped every 30,000 miles as a preventive measure.
I have towed my 15k 5th wheel with just he rv 275's and it did fine it was not a beast but did the job. 6 to 7 percent grades in 5th, 4th your case, thru the mountains in NC. A boost fooler and elbow would help. For a while I had a Banks Ottomind on it till it crapped the bed. All this on the stock clutch and never sipped it, also the clutch had 170k on it.
 My vote would be the EZ and RV's. Economical and a decent bump in power. The Banks tuner added abot 75hp and was not smokey. I have not personally run an EZ. I also am not mountain dweller but have towed over the Blue Ridge many times with the 5th wheel. Thats in the 6000 foot or so elevation.
I'm running the Edge EZ and RV275 injectors (see signature below) and tow the 8K 5er all over.  The last month I towed 2624.9 miles with lots of power for the hills.  The fuel mileage, hand calculated, was between 12.5 and 13 MPG.
To prevent what? If I did that on mine, that would be 10 times (300k) Even spark plugs go 100k miles now. That would be every 3 months on most busy hot shot trucks, not to mention all the big trucks, ag equipment, construction and stationary equipment. Injectors are not that fragile....
To prevent pop pressures dropping below the ideal, or your intended levels. I've found they drop fairly quickly, especially in the first 10,000 kms I think I lost close to 10 bar. One strategy is to pop them about 10 bar higher at initial install. When things wear in, the hope is that they will settle where you want. But they will still continue to drop over time.
I to am not going to be popping every  30k KISS. I'll replace if when I find a reason to. Have 6 or 8 years on my 7x09 injectors
To do this would require your rig to be down for a week, or having a spare set of injectors. Do you really think this is going to happen? It is not a 15 minute job....depending on the make and model it can be a serious undertaking. What about warranty issues messing with a new rig? It is okay if you want to do this but to recommend it?? What does Cummins, Mopar, Bosch or even DAP say? What about all the other makes and models of diesels? If this practice pertains to a second gen. 24 valve, it should pertain to all. Injectors are pretty much the same.
Did I say you had to, and did I say I recommended it? No. I was just answering the question of why one would do that. Also, my rig wouldn't be down for a week. My rig would be down for 3-4 hours while I pop them on my bench with my cheapo eBay pop tester.
We are in the 24 valve Dodge Cummins forum. They are all the same, and it does not depend on make/model.
Who the hell has a new 24v Cummins truck?
Again, I didn't recommend it. I explained why it's not a bad idea, and why one would be interested in doing this. Based on MY personal experience, and no one else's.
I don't know, and I don't really care. Why don't you ask them for yourself if you have concerns?
Again, being that we are in the 24 valve Dodge Cummins forum, I only speak for that truck, with experience from mine.
I don't claim to be an expert, but to say every single injector is the same? That's just not a true statement. For example, what about the modern diesel injectors that share a common rail, with electronic solenoid control?
I'm sorry to bust your balls here. But really. If someone wants to do EXTRA maintenance on they're machine to help improve everything they can, make things more efficient, predictable, and reliable? Instead of judging them, maybe pay attention and you might learn something new. If you don't want to take the extra step or precautions on your equipment? That's fine man. Nobody is judging you. Do what makes you happy.
Humm, why would you single out the 24 valve. Like I said, injectors are mostly the same, the part that matters, is. Why would you disturb a perfectly good sealed and operating injector, thats asking for issues. Rather than using a sub certified pop tester, I will leave mine alone. Maybe you didn't recommend the practice but you did indorse it.
I am happy everyday, thanks.
I stand by everything I said and why. In my 50 year history of owning, working on them and operating (diesels) I have never seen or read about this practice...so yes...there are times I question internet lore.
Enjoy your day.
Edited by NIsaacs
