Truck died in traffic, will idle but dies with throttle (7) DTC codes
- Replies 16
- Views 3.1k
dripley 3 posts
OmahaGen2 3 posts
Mopar1973Man 2 posts
TheBeast 2 posts
Popular Days
I would say it is VP time by the looks of it.
Both can be had at DAP. @dieselautopower Maybe he get you a quote for a package deal... You never know...
Diesel Auto Power was the go to for me when I needed to replace my VP44 and upgrade the injectors to RV275. Good customer service and fast shipping. The prices are about the same for quality parts n
Running fine, turn corner push to 1/4 throttle instantly dies coast to shoulder. Sits for about 10 min to give a once over. turn the key it rough idles for 2 min then smooths out. It continued to do this rough idle start & then smooth out. Towed it home. Changed fuel filter, hooked up my Smarty to read codes. (7) codes
P0251 Fuel Inj pump fail (replaced lift pump 6 months ago carter) (I can hear it run when bumped)
P0252 Inj pump fuel metering
P1688 Internal fuel inj pump controller fail
P0254 Fuel Inj pump mech fail fuel valve
P1693 Generic fault indicating fault in bus or PCM/ECM interface
P0602 Control module programming error
P0122 TPS low voltage
I have not done anything else since changing fuel filter, I would also note that the Smarty gave me definitions slightly dif to what I looked up online such as P1693 JTEC module detectedin companion something or other.
Any words of wisdom before I run pump & fill the stock fuel filter system? Thank you.
