- Replies 29
- Views 7.1k
Mopar1973Man 9 posts
dripley 6 posts
AH64ID 2 posts
IBMobile 2 posts
Luckily the next Friday the 13th with a full moon is 30 years away. I’ve been having the same issue. Phone and computers.
It hasn't happened to me yet. Do y'all think that's Mike's way of allowing the more important opinions to post while screening some of the marginally important ones? Just kidding...you
Not my Ram, but the Toyota decided to wet itself this week. Wife drives a 03 4Runner with 191K on it and it's leaking at the end cap crimps on the passenger side. Not too much, about 1 cup in a 30 mil
Yup, Friday the 13th and a full moon has struck me... Got the transmission and clutch done went out for a short test drive and came back check for leaks or issues. Sure enough the driver side tank blew out started leaking just above the drain cock. Redneck fix. I cut the vacuum breaker off the radiator cap. This will allow the pressure to escape the radiator and not build pressure. I made 84 mile test drive and no issues. I've got a replace radiator in Ontario, OR waiting for me. $282 dollars for a replacement radiator. Oh well...
Radiator lasted 392k miles and header tank seal failed.
