Allowable play in ball joints
- Replies 22
- Views 5.8k
dripley 6 posts
Evan 4 posts
Dieselfuture 3 posts
Remington92 3 posts
If it's about 16th of an inch up down it's probably ok, side to side should be zero. I changed mine with a little play up down because I was doing wheel bearing anyway but when put new ones in the had
17" tires do have limited weight ratings of 3195lbs. There are a few that are currently above that number, but as they go thru redesign and certification they have to drop to 3195lbs. I'v
Seemed to be when I was thinking about swaping to them a good many years back. Plus the 16's had higher weight ratings on them and are bit cheaper. About $25 a tire.
Took my pickup into the local mom and pop shop for a once over and see if they could diagnose my loose steering. Their verdict was ball joints are shot. Trucks has 135k mi and no telling if they’ve ever been changed. After doing some reading it sounds like dodges have a spec for allowable up and down play. You can see how much these move from the wear mark. Does this look out of spec?
