Newb needs help!!
Hi all, I'm the proud new owner of a 01 2500 ext cab 4x4 auto, I've been lurking around cummins forums for the past couple weeks and came across this one and seems a fair amount of y'all know what you're talking about? Not sure if this is were I should unload all my questions but here goes.
  First off I'm an absolute greenhorn when it comes to diesels in general so I don't even understand most abbreviations and lingo I've come across in most posts here, so please be gentle!
 I kinda thought I knew what I was getting into but maybe I'm over my head? I decided it was time for a power & torque upgrade to occasionally tow my 7k camper + toys and came across this truck that I figured had most big ticket items covered with built trans, new inj pump, lift pump, +50 injectors, nice interior, fairly straight body, etc. But now my head's spinning with the items it still probably needs to get it the rest the way up to speed. Just looking to get some opinions as far as priority on upgrades and such because on my budget I can't do everything at once.
No.1 truck has no gauges
  2. No tuner, I would like a smidge more power, (famous last words) would it make more sense to get something with gauges built in budget wise? Was first thinking edge ez & gauges? I know a nice tuner costs some pretty serious coin! And anything else that goes with it, idle control? Etc..??
  3. Has new stock Carter lift pump, P.O. said he had a fass setup and still fried his second inj pump so he went back to stock! Has bigger fuel hose. I'm liking the looks of that belt driven one but $$$! Leave alone for now?
  3. Steering, was minutes away from ordering a new t-style tie rod setup and just read I have to buy new, bigger wheels for the upgrade?? I'll probably replace with stock if that's the case. $$ Stock style track bar seems pretty tight for now. Was going to get steering box/frame brace, bushings,etc.
  4. Rear is swaying, rear shackles and??
Just happened to find a deal on CL for a low mi. Hx35 turbo so I swapped that intending on elbow and boost foolery but just not sure if I'm going in right direction?
   5. Has stock air filter, 4in. Turbo back exhaust.
  6. Killer Dowl pin issue, P.O. (original owner) never heard of it!?
  Thanks for any advice! Like I said, budget does matter, seriously thinking about keeping my gas truck this just seems overwhelming and expensive! I'm a 30yr retired auto body guy, so not afraid to do my own wrenching. Sorry so long winded, thanks for reading.
Edited by dieseldon
typo
  • Replies 45
  • Views 8k
  • @NIsaacs,   I didn't use the 2002 inner nor did I have outer issues at all.  (though I am glad you pulled that together.  the taper on the 99 inner at the pitman arm is slightly longer.  So
  • Just add an "add a circuit"  to fuse 5 in the junction block for your gauge illumination.  This fuse follows the voltage that the dimmer does on your dash lights.  It will dim as the dash lights dim.
  • You NEED some way to know if you're losing lift pump pressure. That should be first "upgrade" and I suggest a real gauge, even if you get a tuner (like a Quadzilla Adrenaline) that can display that pr
Sorry, I kinda got side tracked on suspension, the real dilemma in my mind is still the whole gauge thing. With the mountains here in Idaho I would like a little extra punch and was thinking EZ + gauges, but what about quadzilla adrenaline with iquad built in gauges? List is $700 without screen, use old phone or tablet? Not sure if that price is just starting point? I think EZ & gauges would surpass that? Never seen one in person, would it substitute gauges? (Quadzilla) Plus all the other features like economy,idle control,etc. I realize both would be ideal but $$ anyone have experience with quad?
The only drawback on using the tuner for gauges is if somethings happens with the tuner now you have no gauges. Happened to me when my banks tuner crapped out. Luckily I had a stand alone FP gauge. I added boost, egt, and trans temp after that. Got a good deal on 3 pack of gauges with a dash mount.
I have the Glowshift gauges in my truck and for the most part they are OK.  I've had them about 2 years with no real issues.  That being said, I am in the progress of upgrading them to ISSPro gauges.  I have the FP gauge bought (used) already, just need the boost and EGT gauges.  I did notice the Glowshift EGT gauge is slow to react compared to the Quad Adrenaline built in gauges but the boost is pretty close to the Adrenaline.
Another thing, as Dripley stated above, it's common practice to ad a quart of 2 stroke oil to a tank of fuel??!
@NIsaacs,
I didn't use the 2002 inner nor did I have outer issues at all.  (though I am glad you pulled that together.  the taper on the 99 inner at the pitman arm is slightly longer.  So I made a spacer and it works fine.) (to not run a different inner, you should be able to use the pitman that went with the original '99)    I do run Chevrolet rims so the offset is a bit different, but from the pictures I have seen I agree some could be close.  Though this doesn't make any sense.... 17" rims were not offered in '99....  so I don't know why Chrysler would have designed an upgraded part that couldn't be used until the new body style came out in 2003....  I did mine before there were nay sayers advising me against it....
Here is a copy of a post from Danny Gaston (Dodge off road)
I'm posting this because there is a lot of misinformation on the web and I feel like the right info needs to be posted somewhere. Please do not make this thread confusing; ask unrelated questions in a new thread.
EDIT: The new DOR steering kit info is added near the bottom of the post.
94 to 99 trucks have one size taper in the knuckles and pitman arm.
00 to 02 trucks have another size taper in the knuckles and pitman arm.
03 to 08 trucks have the same size taper in the knuckles and pitman arm as the 00-02 2nd gens.
08.5 to 12 trucks have the same size taper in the knuckles and pitman arm as the 00-02 2nd gens and 03-08 3rd gens.
On 94 to 99 models, the distance between the knuckles is different than all other models.
With all of that said, there are two "factory" HD steering options available. One is the 98 HD setup, which is very good. It converts the steering from a Y design to a T design, which means that the drag link now attaches to the tie rod in a position that is very close to the knuckle. The idea is that the less distance between the drag link and knuckle, the firmer the steering will be. It's a good idea on paper. The 98HD setup works on all 94 to 99 trucks. I will post the part numbers later.
You will see people saying that they used the 98HD on their 00-02 trucks. It will fit, but the taper is smaller on the steering than the taper on the truck, so it actually doesn't sit in the taper correctly. This causes premature wear and some extra play from day one. The 00-02 trucks also use a wider knuckle-to-knuckle distance so the 98HD tie rod ends need to be threaded out more than normal.
The other HD kit is the 08.5 steering upgrade, which can be used on all trucks from 2000 to 2012. This is similar to the 98HD setup in many ways (they look very similar), however it uses larger everything. The tapers, the TREs, the OD of the tube are all larger. This is the largest steering kit ever produced by Mopar. It uses 1.625" OD solid stock on the tie rod, and I believe on the drag link as well (not verified). This steering kit uses the exact same tie rod end ball, socket, taper, and thread as the earlier models (00 to 08). I cut one apart and measured it with a caliper. There is no difference at all. So while the bars themselves are much larger, the TREs are not.
You will see people saying that they used this kit on their 94-99 models. Some will agree that they had to ream the knuckles out, some will say "it fit just fine." The correct answer is that the tapers are larger than the tapers on the knuckles and pitman arm, so again you don't have the proper fit. The TRE won't go in the taper all the way and even though there is enough thread to tighten the TREs down, the contact patch is not matched to the truck. You will also read that people had to shorten the tie rod end all the way or even modify it to make it fit because it was too long for their older 2nd gen. This is because it is longer than what 94-99 trucks use.
So make sure you buy the right kit for your truck if you want to go this route. Keep in mind that some early 99 models may have the 98HD steering setup, depending on the date of manufacture. Dodge seems to make all of their changes in the mid year, usually after March. So there can be some exceptions to the size of the taper around 98, 99, and 2000.
There are other HD steering options out there, which all have their ups and downs.
Thuren Fabrication makes a really awesome crossover steering kit using heims at all four ends. The tubing is 1.5" OD .250" wall and is bent for clearance around the sway bar bracket, and clearance for the diff cover. This is the strongest kit on the market and is one of only two crossover steering setups that I'm aware of. The downside to Thuren steering is that you can't run it on trucks with factory wheels. You will read where people say it won't fit with less than 3" of lift, and this is not accurate. It's all about the wheels and clearing the bolt on the passenger side knuckle. If you have a stock truck and have aftermarket wheels that are either 17" or bigger, or offset more, then you'll be able to run this setup. But Don may tell you otherwise because there seems to be some hangup on "the truck has to be lifted 3" or more." This kit requires you to drill your knuckles and pitman arm out to 3/4" straight bores, so you cannot go back to stock steering or any other steering setup once you do this (unless you replace the pitman arm and knuckles). The other down side is that you can't run a steering stabilizer without either welding some tabs on the tie rod, or using a clamp. Don sells the clamp for $90 and DOR has it for much less if you want to buy one of ours. It's the same thing.
Don's steering seen here:
Pure Performance makes a really good steering kit that is also a true crossover setup, but instead of heim joints, it uses TREs. Ford TREs to be specific. This kit is only marketed for 3rd and 4th gens, however it will work on the late model 2nd gens from 2000 and up. You can buy the kit from DOR or any Pure Performance dealer, but you will need to buy all of the tie rod ends and adjusters separately unless you get it from DOR. The down side is that the kit is very expensive; about $1000 for the whole thing. The TREs and adjusters are $500 and the kit itself is $500.
Pure's kit seen here:
Another option I just discovered is the DT Pro Fab steering kit, which has zero info on their site. It only fits 94-99 trucks and uses large uniballs at the knuckles, and a high misalignment heim for the T-connection at the tie rod end. It appears you use the stock TRE for the pitman arm. The retail is $675 for this kit.
DT Pro Fab seen here:
There are other kits out there from Bulletproof Steering (the most expensive one) and other companies I can't think of right now. Shakerbuilt was one that used to be around and is now out of business. The problem with all of these options is that there is a downside to every one of them.
UPDATED WITH INFO:
DOR's new steering kit is definitely the best setup available, and I'll explain why. This is one of those posts where "yes I own/make the stuff but I'm typing this from an unbiased point of view" applies. So please do your own research if you feel that I'm being too much of a salesman. I'm including this much info because it's important to compare the DOR kit to other kits and understand why it's a better setup.
DOR's steering kit is a totally bolt-in, drop-in setup. No drilling required. It fits all trucks from 94 to 12 and works with any lift height, any size wheel, any backspace/offset, etc. There are no exceptions to this. If you have a 94-12 Ram with a solid front axle, it works. Additionally, if you have already drilled your knuckles and pitman arm out for Thuren's kit, we can sell this in a less-expensive version where it will bolt up to the modified parts. We use a 1.5" OD 1026 DOM tube with .40" wall for the tie rod, almost twice as thick as other options. The tie rod ends are bent for clearance and this allows the tie rod itself to be totally straight, which means it can be adjusted on the truck without having to remove one side or the other. You just loosen the jam nuts and spin it in place. The drag link is made from 1.5" OD 1026 DOM tube with .25" wall, and it is also adjustable on the truck without having to remove either end. This is a huge time savings and also allows you to be much more precise than if you had to remove one end and then reinstall it.
So now that the tubing is covered, let's talk about what joints we are using. The drag link uses extremely high quality FK heim joints with a 3/4" shank and 3/4" bore. These heims have a load rating of 55,696 lbs each. They are heat treated, zinc plated, and Teflon lined. I have seen these heim joints last over 5 years in daily driver applications, with zero maintenance. We use misalignment spacers on both ends to prevent the heim from binding up. One thing we did better than anyone else is put the heims in the proper orientation where they do not bind up so quickly. Most kits mount the drag link to the tie rod so that the bolt holding the heim or TRE in place is in a vertical orientation. Common sense would tell you that as the suspension moves up and down, this will eventually bind, as is the case with the Thuren steering on my truck. So by putting our heim joint where the bolt is in a horizontal orientation, now the heim never binds up. The limiting factor for the steering is the misalignment of the heim at the pitman arm, which has a 26 degree misalignment before it binds up. This is more than just about anybody can use. As an example, my truck with 14" travel coilovers and 11" of down travel will not bind these up.
The drag link is where other stock kits seem to have so many problems, as I will explain at the end of this post, so we are using heim joints on both ends of the drag link similar to what Thuren does. However, ours doesn't connect directly to the knuckle, so it's not a true crossover system. This will allow the kit to fit any truck with any wheel or lift height, period. By using heims, the angle of the drag link will not be a problem for longevity of the kit. Another benefit to not mounting on the knuckle is that you can have no bumpsteer at all. One problem that some people experience with Thuren steering is that it's hard to get rid of bumpsteer. That is created when the track bar and drag link are not parallel, but also when they are not the same length. Most people don't know that. The two parts being at the same angle but in different lengths is the same thing as having a long lower arm and a short upper arm on the control arms. Your pivot points vary so the arc that they travel during the suspension cycle is different, which causes binding in the suspension and bumpsteer in the steering. Our kit is the only one on the market that makes the track bar and drag link the same angle AND the same length. Bumpsteer is completely designed out of this kit.
Now the best part... the tie rod ends. These are custom made by us, in our shop. They are rebuildable, replaceable, fully awesome. There simply is not a stronger tie rod end made anywhere. We take an FK uniball assembly with a 37,000 lb radial load rating and a 7,730 lb axial load rating, that is PTFE lined and takes a 3/4" bolt, weld the housing to some 1.5" OD .250" wall DOM tubing, bend the tube to allow the tie rod itself to be offset from the knuckle to knuckle center line, and the end of the TRE is threaded so they just thread right in to the straight tie rod.
The last piece of the hardware is what makes this whole thing a bolt-in, no drill install. We had some custom bolts machined for this application that allow the straight 3/4" bore of the uniballs and heims to be attached to a tapered bolt that matches the taper in the knuckles and pitman arm. These are machined from stainless steel.
The retail is $599 for the full kit. There are less expensive options if you want to go with thinner wall DOM tubing or if you don't need our tapered bolts (due to having the knuckles and pitman arm drilled out to 3/4" already).
With all of that said, here are some final steering design notes.
I had mentioned earlier that the T-style steering is a good idea on paper. And it's true, that a T style design is better in terms of the tie rod going knuckle to knuckle instead of allowing the drag link to pull the toe in. But here's the deal - people switch to a T style and think that all of their problems are solved. In reality, people are having problems with the 98HD and 08.5 steering just like with the older Y steering. The reasons are very simple:
1) T style only references the way that the tie rod and drag link connect. Y style allows the drag link to pull the toe in as the truck's suspension droops, and push the toe out as the truck's suspension compresses. The T style eliminates this issue. You can see the difference here - notice how the T style allows the knuckles to stay connected even if the drag link is removed, where the Y style needs both the drag link and tie rod to connect the knuckles. This setup causes the toe to change as the suspension cycles.
131_1003_02+dodge_ram_2500_4x4_steering_
2) Tie rod ends aren't designed to run at an angle like they are on these trucks. If you look at the drag link, even on stock trucks, the TREs on each end of the drag link are operating at an angle. They are not flat. Now add in the suspension movement and the steering box pulling back and forth, and the TREs on the drag link will simply loosen up over a period of time, more quickly than the TREs on the tie rod, which never change angles. There are a lot of different directional forces hitting these TREs all the time, but they are only designed for lateral force. This is also why the stock 2nd gen track bars suck so bad. They use a TRE in an application that it was never designed for.
The tie rod end itself is fine because it never articulates, but the tie rod ends on the drag link are wearing out just as fast as before. If you look at how they mount up, you can see why. Also remember that the new "beefy" 08.5 TREs are actually the exact same size, they just look bigger due to the size of the shafts attached to them.
3) No steering kit will fix all of your problems, because there is much more to steering than just the tie rod and drag link. You also need to look at the track bar, hubs, ball joints, control arms, and of course the rest of the steering components (pitman arm, steering box, steering shaft, steering column) before diagnosing your truck as needing a new steering kit. It is easy to throw new parts on, and maybe you will get lucky and fix the right one the first time, but spending a few minutes under your truck checking for play will save you a lot of money and time. If you don't have time or the tools, then any alignment shop should be able to pinpoint the problem areas. As I have always said, don't just replace with stock parts... upgrade. You can often get a much stronger aftermarket part for the same price as a stock replacement.
I will continue to update this with pictures as I have time.
Quadzilla is the only tuner with full control of fuel and timing. You DO NOT require a screen. It can be ran headless. I do this off and on.
2 cycle oil you can pin me I'll help you a bunch being I'm one of the founder to 2 cycle oil usage.
Haggard, thanks that's a lot of good info! If I'm reading correctly, (not one of my stronger powers) that mopar kit #52122362ah should work on my 01? That DOR setup really looks good, maybe next go round?
 Mopar1973man, thanks, right the quad can be used without head, but with monitor would it be a viable replacement for gauges? (Tho not ideal) And do you have to buy all kinds of accessories to hook up once you have the unit?
I know you addressed this to M1973M, but I will chime in anyway.  I believe for fuel pressure you will want a stand alone gauge or a dummy light that comes on if pressure drops too low.  I installed a dummy light in my ex girlfriend's truck a long time ago.  One day while towing my Airstream, about 3 miles after filling up with diesel the light came on.  Immediately stopped and walked to buy 3 new fuel filters.  Had to change filter twice before all the crap we got at that filling station was cleared from the tank.
Phones and tablets get stolen or break.  If that happens, you lose your gauges!  Not cool on a $$$$ VP44 injection pump.
Learned about that one here from @Mopar1973Man and @dorkweed I believe. They were 2 very big proponents of the 2 stroke. That and good fuel pressure got me 277k out of my last VP.
Hag's poster didn't use Mopar numbers but this info explains it in detail. Plainly says the HD 98-99 oem tie rod taper will not fit the 2000-2002 trucks. The taper is the same for 2000-2012. I think your kit fits the 2000-2012 trucks. Some forums use #52122362AF but might be the same as your "AH".
"94 to 99 trucks have one size taper in the knuckles and pitman arm.
08.5 to 12 trucks have the same size taper in the knuckles and pitman arm as the 00-02 2nd gens and 03-08 3rd gens"
Some good info here and backs up Hag's post.
https://r.search.yahoo.com/_ylt=AwrJ61Qi7GBeafYABQpXNyoA;_ylu=X3oDMTBzdWd2cWI5BGNvbG8DYmYxBHBvcwMxMAR2dGlkAwRzZWMDc3I-/RV=2/RE=1583439010/RO=10/RU=https%3a%2f%2fwww.rme4x4.com%2fthreads%2fbullet-proof-dodge-steering-upgrade.78067%2f/RK=2/RS=sVZ3YjC6FJCDTnneXRz4dkUlX.U-
A little more info:
All the Mopar #52122362AE, AF, AG, AH, AI, AJ, and AK have been superceded by "AL".
Also be aware that all upgraded Mopar Tie Rod Ends had a recall back awhile ago. NAPA was included in this recall too. Stock stuff was no affected.
Double check the part number to make sure it was superseded.
I have a Glowshift combo gauge now it works okay but is cheaply built. I had pillar gauges in another truck. In my opinion none of the gauges are dimmable enough and are annoying at night.
I can dim my Isspro's all the way to dark just like the dash.
I agree.  The gauges may be little brighter than the dash lights, but it may also just be that the old lights are behind 19 year old plastic.
And, with that special cord (part number R82003) the light dimming sensitivity can be adjusted to match the dash.  I do not yet have that cord as I forget to order it every time I have a Geno's order (cheapest place I've found so far for the cord).
@Haggar thats how mine are done.
I just EV1's. No special cord needed.
On 3/4/2020 at 8:40 AM, Mopar1973Man said:
Hence why I just went back to factory parts which lasted over 350k miles before failure. The biggest thing is no lifts or oversized tires and this will make the front end last much longer. The oversized wheels, wild offsets and lift kits tend to screw with the geometry of the axle causing part failures to occur faster.
Not a problem I've got two shops and work on Dodges and Chevy trucks quite a bit. Even a few Fords now and then...
Moparman drives on by stranded jacked up trucks, a lot of times by going underneath them. He knows when the market reaches bottom too .
