- Replies 45
- Views 8.7k
dieseldon 9 posts
Mopar1973Man 8 posts
dripley 5 posts
NIsaacs 5 posts
@NIsaacs, I didn't use the 2002 inner nor did I have outer issues at all. (though I am glad you pulled that together. the taper on the 99 inner at the pitman arm is slightly longer. So
Just add an "add a circuit" to fuse 5 in the junction block for your gauge illumination. This fuse follows the voltage that the dimmer does on your dash lights. It will dim as the dash lights dim.
You NEED some way to know if you're losing lift pump pressure. That should be first "upgrade" and I suggest a real gauge, even if you get a tuner (like a Quadzilla Adrenaline) that can display that pr
Hi all, I'm the proud new owner of a 01 2500 ext cab 4x4 auto, I've been lurking around cummins forums for the past couple weeks and came across this one and seems a fair amount of y'all know what you're talking about? Not sure if this is were I should unload all my questions but here goes.
First off I'm an absolute greenhorn when it comes to diesels in general so I don't even understand most abbreviations and lingo I've come across in most posts here, so please be gentle!
I kinda thought I knew what I was getting into but maybe I'm over my head? I decided it was time for a power & torque upgrade to occasionally tow my 7k camper + toys and came across this truck that I figured had most big ticket items covered with built trans, new inj pump, lift pump, +50 injectors, nice interior, fairly straight body, etc. But now my head's spinning with the items it still probably needs to get it the rest the way up to speed. Just looking to get some opinions as far as priority on upgrades and such because on my budget I can't do everything at once.
No.1 truck has no gauges
2. No tuner, I would like a smidge more power, (famous last words) would it make more sense to get something with gauges built in budget wise? Was first thinking edge ez & gauges? I know a nice tuner costs some pretty serious coin! And anything else that goes with it, idle control? Etc..??
3. Has new stock Carter lift pump, P.O. said he had a fass setup and still fried his second inj pump so he went back to stock! Has bigger fuel hose. I'm liking the looks of that belt driven one but $$$! Leave alone for now?
3. Steering, was minutes away from ordering a new t-style tie rod setup and just read I have to buy new, bigger wheels for the upgrade?? I'll probably replace with stock if that's the case. $$ Stock style track bar seems pretty tight for now. Was going to get steering box/frame brace, bushings,etc.
4. Rear is swaying, rear shackles and??
Just happened to find a deal on CL for a low mi. Hx35 turbo so I swapped that intending on elbow and boost foolery but just not sure if I'm going in right direction?
5. Has stock air filter, 4in. Turbo back exhaust.
6. Killer Dowl pin issue, P.O. (original owner) never heard of it!?
Thanks for any advice! Like I said, budget does matter, seriously thinking about keeping my gas truck this just seems overwhelming and expensive! I'm a 30yr retired auto body guy, so not afraid to do my own wrenching. Sorry so long winded, thanks for reading.
Edited by dieseldon
typo
