airdog 4g 150 install trouble
- Replies 50
- Views 7.8k
Welcome @dieseldon...you really should look into a mechanical fuel pump (Fuel Boss, Assassin or Power Driven Diesel) if you haven't yet. The install is more straightforward and the customer service i
I think?? Maybe where it says to be sure to connect old return line is what got me off track? Bullet, not just that but you have to modify module and also run1/2 lines from tank on up. Well
Messing with the tank is just to get all the fuel lines connected and abandon all the stock fuel lines for new 1/2" supply lines. Location of the pump does not matter. Though as close to the tank as y
Hi all, so , recently had my fuel pump go belly up and decided to upgrade to an airdog, I know there were a couple options and I was planning on possibly adding power down the road so my research pointed me to the airdog 150.
I call the airdog tech support and he recommends the $200 factory replacement with lifetime warranty, I'm game and get it ordered, only while I'm waiting for it to show up I find it's only got a 4yr warranty, and technically isn't a 150, I call the guy back and he admits he made a mistake, what would I like to do he asks? Well, what's my next option with the lifetime? Him; the 4g 150 and you use your stock filter and still don't have to remove gas tank since my pump is engine mount. Well for $100 more I get that one coming. Well surprise! It shows up and it turns out you not only have to get to top of tank but remove and modify the fuel module!
I call him back and tell him I'm not thrilled, him; Oh, with the 150 you have to, I forgot, well you can send it back if you want, but it's really a pretty straightforward install. How difficult could it be I say! And I dive in,ended up pushing the bed out of the way, not too difficult, pull out the fuel module and looks nothing like directions but might work? But this one I can't get over, supposedly you're supposed to use the old suction line as new return line, with no instructions or hardware (fittings) to do it! Really don't want to start cutting lines and try hose clamping stuff together, Also there's no instructions or hardware from the filter up to vp.
Sorry for the rant, but my question, has anyone installed one of these? I'm going to call Monday but WOW! Maybe it's just me? Can't find any info on youtube or anything, just for the "100" which is a completely different install.
Thanks for any replies!
