Rocker panels cab corners
Well I ran out of beer cans to keep up with this rust bucket so I believe it's time to address it before the whole thing rots away. Got some slip on rockers and cab corners on the way from eBay $210 shipped for both sides. I wanted to get all 3 back, inner, outer but for that kinda money I can almost buy a rust free cab and maybe I still will one day, buy a whole truck to rob parts off like @That Guy just did. Another option I had was to have a local metal shop bend me some rockers out of ss but when I shoed him what I was doing he said he tried it before for others with bad results and lots of wasted time, so my dreams and hopes went down poop tube when he told me that. I wanted to get it done once and never worry about it again. Anyway once i get my stamped recycled beer can from who knows where made rockers I'll be digging in to this long dreaded project. I called lmc and they said their parts come from overseas too and they were on backorder for slip on rockers so I just went with eBay, probably same garbage. Now I just hope inners have some meat left that I can clean up and salvage, the back side is part of floor pan and has some rot in spots but should do for now. I was also going to cut everything out and use a square tube like some have done, but figured I'll try the outer shell for now, it may last 10 more years this way and then... who knows by then....
Anyone that has any good advice or beer support feel free to derail this thread. :cheers:
  • Replies 87
  • Views 19.9k
Most of the pups out here play hard go get there truck sloppy with mud and never wash it. After a awhile the salt gets into the mud and accelerates the rusting process. Just about keeping the truck clean of mud and all drain holes open and flowing. Less water can stand in the bottom of the rocker panels the better off you are.
Old story but when we moved to Idaho we only had the 1973 Dodge Charger and the 1978 Dodge Magnum XE. On the Magnum had a drain hole plug with body sealant. So the rocker panel on the driver side just below the rear window glass was rusting out. I had a excellent body man next door. He crease the metal so it was stepped and not sure what kind of fastener or glue he used but no welding. This is the best way to do it so there is no burnt metal that will rot from inside out.
I've debated on using panel adhesive instead of welding myself, not sure what I'll do yet, but it makes sense if you have everything painted and then stick new panels on then it won't rust on inside where you weld, otherwise how do you get in there to paint. Link with video above shows useing a tube with funky fitting on the end, spray is kind of like our injectors sideways and then attach it to the spray can and as you paint you pull back on the hose. The only problem outer rocker panel is so close to the inner you're not going to fit much in there, and going through the back where the plugs are is not going to reach the outer layer either. So yeah adhesive does make more sense, plus they say it's stronger than welding.
Edited by Dieselfuture
There certainly is a way to glue panels on without welding, used to glue entire roof panels on, quarter pnls. rust repair patches, etc.  The stuff is called 3m metal bond, there are different brands but I always preferred 3m, no odor, sandable, it's a epoxy tube, and as a matter of fact I have some in my garage right now. You can't even imagine how many use's I can find for the stuff! I can't live without it!  You can buy at paint supply store or amazon.
We tested in vice to see if you could get it to separate, the metal tore first. You can get it to release with a torch.
The glue itself is corrosion protection.
For a patch you want to grind down to bare metal around both edges, and opposite mate surface, then cover with the glue, either clamp and wait to set, or if there's no way to clamp drill 1/8 in. holes and screw, after it sets remove screws and fill.
 The applicator gun is quite expensive, the body/ paint supply store will usually rent you one or you can just push out the bottom with some big sockets and mix with putty knife or?
 My advice if you want/need some great glue to end all, get some.
 A friend of mine used that stuff on his vehicles. He says it's much better than welding and perfect for someone that doesn't have the proper welder or experience to weld sheet metal panels. That's takes time and patience. And as mentioned, you won't be putting the heat to the pieces which will burn off any corrosion protection that was sprayed on prior to install.
I wouldn't say it's stronger than welding, there's a place for glue and a place for welding, sometimes glue and weld on the same panel like quarter panels.
Also works great for repairing plastic bumpers!
I still wish I could have had someone bend me some rockers out of SS. This was my drawing for him, I slightly modified the original design as it's a 3 piece and this one is only 2 but 1/8" SS would of been up my alley. Would be more work but last forever....PXL_20201209_193533220.jpg.6ea859ae11d82d87d0b17db74c6c9872.jpg
You could probably buy an inexpensive box brake and make them yourself. Would likely need to make them in two pieces because of length. Your a handy guy. I think you can do it.
May work with thin gauge steel, I was thinking 1/8 for durability like rock sliders :drool: not that I need them. Was also thinking using square tube like a 3x3 or 3.5x3.5" but there's always but... Not sure what I'll do yet once I get old ones off, how bad will it be, I can only imagine :think:
I have always had a vision of me sitting in my truck with it rusted into pile with the Cummins still running. Now l could do it with rockers still shining too.:cool:
Maybe IBMobile has a picture although he's been a bit lax on that lately.
You can always tell where Dripley has parked by the red rusty streaks running toward the parking lot catch basin. :thumb1:
More like an oil trail.
If dodge had just put proper corrosion protection behind their sheet metal they would probably last a lifetime anyhow, I sure hope that $10-$15 profit helps them sleep at night!
Wealth acquired by vanity shall not last.
Sunday lesson for today :thumb1:
Unfortunately for us it's not in big corporation agenda anylonger, most higher ups I've spoken on this subject, I've been told that everything is aimed at first owner or 10 years max, not like back in good ol days where things were meant to last. Doesn't even matter on what country we're talking about really. Seems to be world wide disease these days. Only few select companies are making good products still but of course not many can afford that.
So unfortunate, take a look on the back side of say mercedes benz, volvo, some other Euro's, caked with waxy corrosion protection.
Too bad American companies designed disposability into their products.
I still would never own one of those over engineered Euro nightmares tho! 🤑
Lol guess you make a good point. I have a vw jetta Diesel I got as a run around car. It does have an underbody coating for corrosion and even came with a 10year warranty for rust, if any shoes up any dealer fixes it free. Still I say nothing is designed to last as long as it used to be. I'll let you all know when my first rust spot forms on vw, it's a 2013 with a 2.0l and 6 speed. Wouldn't of gotten it otherwise. Seen over 50mpg in summer more than once if I drove nice, mid 40s in winter.
You could just use that panel adhesive to glue on more beer cans!
Speaking of iron oxide...
Been restoring this since I was about 10. 3000lbs of steel replaced. The side sills and floor have been completely replaced. Stainless steel cars do not rust out. The floors fall out from 40 years of roof leaks. Stainless would likely last longer than the truck. There are many rolling around pushing 80 with, relatively, no issues.
That Guy, very cool. Lucky to have no compound bends or curves to deal with. In a sense, made to last because you can work on it instead of scratching your head. Or like IBMobile, who is very smart.... drives 1500 miles to my place and has me do all the scratching. :lol:
