Quadzilla adrenaline for mpg's is it worth it?
 I'm asking this in light of the recent fuel price spikes. I don't mind paying extra for fuel because I didn't buy a 3500 dually for milage but, out of curiosity if a person were looking for mainly mpg gains would the quad investment be worth it? Last I looked they are fetching about $700 new. That would be a large investment for some people (me included at the moment). Thoughts? Thanks!
  • Replies 78
  • Views 18.5k
  • just done the maths and I just paid £1.29 a litre this works out at $6.77 for your gallon or $8.05 for our gallon
  • Thing is there is 2 sides to it,  1. You can if you want dive in and build tunes, this needs time to understand whats what and time to build a tune and test OR 2. Download a tune that i
  • I like the Quad because I like pushing buttons. Just ask my wife!
18 hours ago, LorenS said:
This tank of fuel I'm running the Quadzilla in the "super secret" mode where it only adds timing to what the ECM is commanding, and it's based on RPM range (1500, 2000, 2500, etc.) I believe if you set 1500 to 2⁰ and 2000 to 4⁰, it would add around 3⁰ at 1750 RPM; probably not a linear function.
@LorenS, I thought it was everything set to zero and use max timing to add on top of factory? at least that's what I thought was said in one of the other threads.. could be wrong..
Correct. The main page under timing you set all them to ZERO. Then under max timing you set for the PLUS amount over stock.
7 hours ago, Dieselfuture said:
Neither can I.
I assure you it still works. I have my Level 1 set to 100% so it's basically stock. When I flip back and forth on smooth ground between Level 1 and 2 I can see the timing jump to what is expected. Now, it may be that Adrenaline ignores the 1500, 2000, etc. settings and just scales exactly like I have it set. But entering settings above 0 for those RPM levels doesn't disable the tune. My truck would run like crap if it only had 4⁰ of timing at 2k RPM!
Drive over 400 miles today, part of it at 80 MPH and still managed 18 MPG. And that's with a big fuel leak from who knows where. Or whereS, plural.
I believe  when they say "RPM Timing Max", they mean this whole screen, not just the "Max" RPM slider, way over on the right.
Edited by LorenS
I pretty sure the MAX slider is only to control how high the cruise timing can go above the rest. Being the cruise timing is ADDED to the max value this means the max slider will control how far your cruise time can go.
 This is an example of what I would be confused on if I had an adrenaline.
 I don't get alot if the tech talk when you guys start comparing tunes and what not. :ahhh:
It's not as bad as you think, it looks intimidating at first, after you spend some time with it you start to realize how easy it is and thinking why haven't I got one sooner.
OR
2. Download a tune that is in the ballpark for your truck that someone else spent all the time messing with it load it and drive
I'm in camp 2, I don't care if my truck might be able to do 300 more yards to the gallon or smoke tyres 200 rpm lower, what I do care about is my truck drives better, feels better and is nicer to drive, all with very minimal effort on my part.
One the other hand someone in camp one may well have the time to tune to perfection and relish the task,  I'll just spend $3 and download it later :thumb1:
It really is as easy as you want it to be or as hard
Yep.
But then someone comes in and clears the muddy water up to a degree.
Right when I convinced my self to keep the comp. I saved the money twice to do it and life got in the way. So now I have it saved up again and I cant get off the fence about it. The handrails keep getting in the way.
A quad would be fun to explain to the wife with a brand new turbo and a bluetop steering box sitting. Whats another 700 bucks amongst a married couple.
I also don't see the point in building a tune now as it has all been done before many times over
 That's another issue as well. My wife doesn't mind some of my expenditures but $700 might be a very tough sell. Hard to convince her why I "need" this for a truck that I have already declared super reliable and should last a long long time. Ugh
If I do get one I would probably have delivered to the job and put on the truck on the sly. I think I will at least wait until I see how the new turbo reacts with the Comp.
 I may consider getting one. I have to sell one of my motorcycles (was going to sell it anyway) and have declared that money to be "truck money". Original plan was gauges, injectors and fuel line upgrades. Maybe a quad will be the first big mod?
But the cruise timing is set to Zero to get this "secret" tune to work.
When I bought the turbo back before Christmas. The day after I ordered it I walked and put $450 in her hand and told her that I bought my present now you get to buy yours. But since mine just came a couple weeks I think she would like to see another 459.
 I'm thinking with my technical handicap I may consider a quad XZT+. It will have a tune loaded on it, only a couple of connections and if I understand things correctly I can load a different time to it later if I want to. Not to mention the price point. For what I would spend on the adrenaline I could get the XZT+ and gauges. More toys for the money!
Edited by Doubletrouble
Spelling
13 minutes ago, Doubletrouble said:
 I'm thinking with my technical handicap I may consider a quad XZT+. It will have a tune loaded on it, only a couple of connections and if I understand things correctly I can load a different time to it later if I want to. Not to.kention the price point. For what I would spend on the adrenaline I could get the XZT+ and gauges. More toys for the money!
Not a bad way to look at it.
Hope you know what you doing56bb1bfb55664f4408aa8ce8b5bcb301.jpg.eef933bb0566a08cb86fe29cf2016665.jpg
