Doing the w-t gound mod
- Replies 18
- Views 3.5k
Doug Dear 7 posts
Mopar1973Man 2 posts
dripley 2 posts
Dieselfuture 2 posts
Popular Days
Mine only had one charge wire that went to drivers side battery and now it goes to passenger side with a 150amp breaker. Where do your wires go to now? And if I were you I'd get rid of that fram
Not sure what that is. I have had both the Bosch and ND style alternator and the only wires either one had was the charge wire and the two field wires that plug into the back. I believe to blue wire c
The batteries are paralleled, (wired as one battery bank) which dictates that both batteries get replaced at the same time with the same manufacture dates whenever one battery goes bad. Th
I am finishing up my w-t ground mod. I have been doing other projects and have forgot. So the 2 wires from the alternator one is the output that I am going to hook up to a circuit breaker and battery. But what is the other wire? Where did it hook up to?
