Thinking about getting a 3rd gen.
Since we got the camper, my wife casually mentioned getting a newer truck.  For me that just means newer than what I currently have but nowhere near a new truck.  I've noticed a couple 3rd gens for sale and the main thing I am interested in having would be a real crew cab with a manual transmission.  The 2nd gen I have now, I've had longer than any other truck, just over 7 years while I usually change up around 5 years.  I've heard the 3rd gens tend to need injectors every 100k miles, but aside from that not much else.  I recently rolled over 250k miles as well and know that in my price range I'll be looking at truck with around 200k already.  My truck mostly just sits anymore unless I need to do truck stuff so mileage accumulation has dropped considerably.  Having a tough time deciding if I should throw some more money at the 2nd gen or start over with a 3rd gen.
  • Replies 32
  • Views 7.2k
  • Sycostang67
    Sycostang67
    The wife and I had a long discussion last night and have decided it would make more financial sense to keep the 01.  I told her it was going to need some things to keep going the way I want it and she
  • I keep standing on the same soapbox, I think it's nutso to pay high dollar for such high mileage.    the used market is crazy right now.      by 194k miles there is so much that needed to be
  • I'm keeping mine; it does what I want which is pull the 5th wheel.   Since October 2019 : Dynamic stage 2 trans, 4 new Michelins, paint and body work, new LMC dash, new speakers and amp, bed rail cove
Just spending a fifth of what a new trucks costs would build a far more reliable upgraded 2nd gen. Easier to work on and you also know the truck well. Put the savings into a Lithium mining company for electric cars batteries :thumb1:
In my opinion it's a stepping stone, I don't think it's the future. Be careful...
Lithium is not a long term solution,  I am betting within 10 years lithium batteries will no longer be used for new EV's.  There is a SERIOUS influx of cash being poured into EV.  That cash means research and development.   This is going to lead to better technology, always has always will.
it's gonna be hard to know where to stick investment $$ before the tech comes out, it will be very hush hush.
Anyways Even though we bought a new truck we bought a base model,  My 2000 had more "opitions" than our current truck. I think that leads to less issues,  there isn't much in the truck that hasn't been well tested over the last 3 decades.   Thankfully the wife was on board when i told her the more fancy stuff we get the more is likely to break or have issues.
Put some cash into the 2nd gen hopefully it keeps going for awhile for you.
Worth noting that seeing some of the truck owners, people with older trucks that are kept so nice and built so beautifully that I find myself taking a closer look while the new ones get ignored. Not on purpose mind you, just there's something about a well kept older rig that's very impressive.
On 7/22/2021 at 7:45 AM, AH64ID said:
04.5-07 5.9 pistons are of the non-reentrant design and arguable the weakest piston ever used in a ISB motor.
@AH64IDare you saying that if a person were going to purchase a 3rd gen, stay away from 03-07?
Told my son a couple months ago I might drop 10k on my truck after I retire. Pretty much told me I was crazy. Then he found a deal on a 98 model S10 pickup for 800 bucks. He loved the S10's several years back and I believe he has caught old truck bug just like his daddy. I am loving it.
No, 03-04 are very solid 5.9s'. Even 04.5-07's are good engines, but they are more prone to piston problems than any other generation.
I'd rather have a 3rd gen 5.9 than a 3rd gen 6.7, especially if you live somewhere you can't delete.
Two methods of deletes.
  1. Physical deletes of the emissions
  2. Software delete of the emissions
When you do the software method nothing is removed from the truck so it visually passes the inspection. Software is turned off to all the emissions systems. It will still regen but much much less. I will not suggest any physical deletes because of the amount of equipment that is removed and will not pass a visual inspection. I've done it both way now and software method is the fastest and easiest to do just need to flash the ECM with a delete tune.
If for any reason you need to return to OEM stock tune the tuner will flash it all back to functional. All the emission system will be back on line. Takes less than 15 minutes to do.
You can't turn the software off to all emissions equipment and leave it all installed. You can reduce certain items, but it's not considered a delete.
Edited by AH64ID
3 minutes ago, Mopar1973Man said:
As far as I know the regen will still occur but much much less... EGR is turned off and not used. No codes will be thrown.
Correct you can turn the EGR down, or off, but that's still not considered a delete. A delete is the removal of the equipment.
On the 13+ trucks I don't think you can get around the 24 hour run time regen, but then again the 13+ trucks don't use much fuel at all to regen.
