- Replies 39
- Views 5.3k
Mopar1973Man 9 posts
JAG1 8 posts
MikeH 4 posts
Tbird9140 4 posts
I"m thinking the carrier bearing or U joints on the driveline(s). Also differentials oil levels but, I am tossing this out there for something should be checked periodically anyhow.
I've done a front bearing a in a friends shop in down in south Idaho. I didn't have access to all the materials I needed. I typically anti-seize everything. Needless to say after one winter and having
On a stock turbo set up the top boost pressure looks a little low; should be 18-20psi. Over 20psi and the ECM defuels the engine unless there is a "boost fooler" installed. Easy to check the tu
If its not one thing its another. With the help of you guys finally got the obvious issues resolved with my white beast. Now however about a week ago the truck started producing a new quite loud sound when I let up on the accelerator. Hard to reproduce in letters but sort of a "whirrr" or "rurrr" noise that starts the moment I take my foot off of the fuel pedal and continues until the rpms drop. The harder I am accelerating when I release the pedal, the louder it is. I do not hear it when I am accelerating but at that time the exhaust noise may be covering up the sound. I don't notice any driving issues (truck seems to be running normally) and no check engine light, so can't report any consequences of the noise. The noise starts up loud and trails off as truck coasts slower, ceasing when the rpms bottom out. Can't really say if it is coming from 5.9 or 47RE. Don't want to be driving the truck if this is the sign of a bigger problem as I have had to already replace one VP44. Any thoughts or suggestions? Any tests or checks I should undertake of the engine or tranny to diagnose my issue. It is a bit unnerving to drive in the city and hear this noise every time between traffic lights. Thanks again for any help.
