Watch the weather for this winter.....
I gotta get my firewood finished for the year. I need to make 2 more runs out to the forest. I'm watching the weather change now here a bit colder in the mornings now down to 47-52*F. I'm kind of figuring on a not as cold winter but a snowy winter.
VP44 PSG fuel cooler ideas
Simple way of checking this and being sure there is no voltage loss in the wiring to and from the VP44. That is called doing a voltage drop test which happens to be in the article database already. The only difference is that you will not be checking while cranking but while the engine is running (wiring under load). Any wire with a voltage loss of 0.2 or more is a instant fail. http://articles.mopar1973man.com/general-cummins/34-engine-system/136-voltage-drop-testing-of-wiring-and-feed-cables Or another way is to ohm each wire from end to end and if the ohm is greater than 5 ohms its a instant fail.
SuperTech
Dorkweed is right Toilet paper is completely safe for filter media. I've got the Frantz Filter on my truck and continue to run 7.5-10k oil changes.
Really? Yes Sir... PM sent.
I would tend to say this would be more so common with weak battery cables or weak batteries. Because there is one rule that will never change. Watts = Volts x Amps So if the Watts or load of the device stays the same and the voltage is reduced from normal 13.5-14.5 volts down to 10.5 during a hard crank now the Amps always will jump up in respect to the loss of voltage. So same would be true for devices in the VP44. So lets say the transistor is marginal about current flow it could be just a bad ground cable on the battery that would increase the current flow on the VP44. Here what I mean. 100 Watt load = 14.5 Volts x 6.89 Amps 100 Watt load = 13.5 Volts x 7.40 Amps 100 watt load = 10.5 Volts x 9.52 Amps Cummins States 8 Volts is rock bottom voltage. 100 Watt load = 8.0 Volts x 12.5 Amps So just weak connections, bad ground or weak batteries could add extra current flow or heat to a device or single component. Food for thought...
ABS Sensor
I would say its suppose to be grounded. I would redo the that back to a clean body ground.
Nissan Murano Cross Cabriolet...good bad or otherwise?
Wow. You did good.
My first Youtube video!
Like with Linux I pre-process the video file with KDEnLive by converting to like a MPG4 or MP4. This typically compresses the file a bit more. Then upload it. My speeds are nothing to write home about at...
(Big Grin) You must of had fun sitting in the Captains seat of that beast. Fixed your youtube link..
That brings up a valid thought. How many people have butchered battery cables? How many have butchered electrical systems? How many have let their battery go dead or below 10.8 volts? How many have not paid attention during jump starting another vehicle and cross the polarity? All these things will affect the life of the alternator at some point or another. Like my battery cable are absolutely perfect like new yet. (0 voltage loss during cranking) I've never cut or modified any power system wiring on my truck. No added grounds or anything. I'm very cautious about my batteries I will refill with distilled water and then equalize charge the batteries while disconnected from the system once a month. I've never let my battery go dead! I always call out "Red is POSITIVE" to the other person so there is no mistakes.
This exact configuration is on the back of the alternator now. (Full wave rectifier). So if you put this on the charge lead there would be zero or very little voltage would be at the far side. Why? Because you only see the rectified AC already rectified DC. So if there was 0.1 AC noise from the alternator the output now would be 0.1 DC volts.
Be careful... If you place a diode in the line so positive DC will flow also the positive side of the AC waveform will still flow but negative side will stop. There is going to be more than a single diode. Remember it takes 2 diodes minimum to filter AC down to DC. 4 is called a full wave rectifier ans 2 is called a half wave.
Ok. So how would you create a filter that can hold the max current flow of the alternator like during grid heater cycles in the dead of winter without burning up the filter itself? It would be the logical thing to do but can it be done? Could there be a filter device added to the charge lead of the alternator that would warn or disable the alternator if the output is to high in AC noise? Now its time for Yankneck to think on this one?
Just like putting a noise filter on the PCM for torque converter lockup issues. Now you have protected the PCM or VP44 but now the other devices take the AC noise as well. Remember its just easier to keep a clean alternator than to attempt to filter every single device and prevent AC noise introduction. Again I'm on the home stretch of 200k on this pump. No other device issues either. It would be easier to just remove the alternator and then there is no more AC noise issues period. Pure DC power solely from the batteries.
Thanks for the video!
Here is what Ed is talking about... http://en.wikipedia.org/wiki/MOSFET
Here you go.. http://en.wikipedia.org/wiki/Transistor Transistor as a switch Transistors are commonly used as electronic switches, both for high-power applications such as switched-mode power supplies and for low-power applications such as logic gates. In a grounded-emitter transistor circuit, such as the light-switch circuit shown, as the base voltage rises, the emitter and collector currents rise exponentially. The collector voltage drops because of reduced resistance from collector to emitter. If the voltage difference between the collector and emitter were zero (or near zero), the collector current would be limited only by the load resistance (light bulb) and the supply voltage. This is called saturation because current is flowing from collector to emitter freely. When saturated, the switch is said to be on.[29] Providing sufficient base drive current is a key problem in the use of bipolar transistors as switches. The transistor provides current gain, allowing a relatively large current in the collector to be switched by a much smaller current into the base terminal. The ratio of these currents varies depending on the type of transistor, and even for a particular type, varies depending on the collector current. In the example light-switch circuit shown, the resistor is chosen to provide enough base current to ensure the transistor will be saturated. In any switching circuit, values of input voltage would be chosen such that the output is either completely off,[30] or completely on. The transistor is acting as a switch, and this type of operation is common in digital circuits where only "on" and "off" values are relevant.
need some clarification...
Kind of like a weird deal on GMC/Chevy's they used two different sized U-joint on each end...
Yea I got a spare VP44 on the shelf ready for tear down. Its a 027 Rev pump so its the newest out.
Motor Oil's cuss and discuss
Actually you hear more about the carnage of someone doing something stupid.
I think transistor damage is partially AC noise and poor electronics (modules). I still can't see 130*F being a issue for transistor. I've seen amplifiers get quite hot. CPU in a normal every day PC is loaded with thousands transistors. Both AMD and Intel processors will run upwards of 160-180*F on a full load run. So why does a simple single transistor fail in a PSG unit at low temps (not enough to trip the P0168 code). The only other thing is maybe the early years Bosch used margin transistors in the manufacture and they couldn't tolerate the load and POOF! So now they have updated the transistors to to tolerate loads of the VP44 solenoids.
Toy Hauler problems befre big trip...
Wow! Nice find on a cheap (free) repair!
spin on trans filter
He's wanting the luxury of dropping drain plug and spinning a old filter off and new one on. Kind of like Subaru's got. Then you never have to drop the pan for any reason nor have the huge mess. Dodge has always had the nice big pans that would flop down on one side make a huge mess then you had to change the filter inside the transmission.
Lope at Start up? VP44?
I know you did the APPS sensor voltage. Just remember one thing idle as long as the OE APPS sensor is BELOW the tag voltage then the ECM will IGNORE the APPS voltage and use internal ECM software for Idling.
Almost 300k
Naw... Start worrying when you pass this gent... The reason why is the odometer stops at 999,999 and there is now way to track anything from that point. But the Cummins will keep on running there is reports of a 1.67 million mile Cummins still running. Oh welcome to the family...
