Truck crane?
Might check on this... http://forum.mopar1973man.com/index.php?/classifieds/item/9-truck-hoist/
EGT Probe Locations
Well you could drill and tap 3 probes in the manifold but I would space them out properly. I would most likely try to stay in the 4, 5, 6 port and start close to the mouth of the turbo and work my way back up the 4, 5, 6 port. Can't see using a switch because they still need live data to function.
Another day at work...
With the heavy spring rains and snow melt yes that could be a waterfall.
The secret behind a turbo....
-= Click here =-
New toys drug home today!
Yes I do... My BigTex (1,800 pounds empty) with that 4 foot tall flow through drag down the same amount as 31' Jayco. If I ditch the back gate I can gain a bunch back.
It still has the original Willys Hurricane flat head 6 cylinder engine. We just pulled the head off to have it checked for cracks.
How to test VP44 overflow valve
All the internals of the VP44... If you need better pictures of anything let me know I'll put it apart and shot more pictures. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/437-bosch-vp44-injection-pump-exploded-view
I just figure I'd give you all a feel for where I work at... Anything and everything come in our doors down there. Cars, trucks, vans, buses, ATV's, and even big trucks... Jobs were piling up today waiting on parts, trying to get other finished and sent home, etc. Just when you though your caught up it piles right back up...
All right here... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/88-bosch-vp44-injection-pump-overflow-valve The bottom hole is only for air bleed it too small for cooling. Even Bosch states 70% of the fuel should be return for proper cooling and there is no way you can get proper cooling in that tiny hole.
Nice!!!
96 Dodge Ram 1500 & BigTex 70TV hauling firewood
The tough part is you need to see what the BTU value is of each. Some people base it solely on BTU levels. this why Red Fir and Tamarack (Larch) are popular out here is because they are the top of the BTU list. You should base your firewood on you BTU requirements of your house. Like early winter we need a light BTU wood that burns rather clean when choked down. Then come December and January we need some seriously fuel wood that has the BTU's. Like Red Fir and Tamarack. So like if you build a fire with Red Fir and choke it back so you don't roast in the house then you have a problem with sooting or creosote build up. Each house, size, chimney length, family preference of temp, etc plays a role in what to get. Then you need see each species of tree for characteristics like splitting and cutting. Some of the other trees I tend to look careful about is knot density and limb size. Great to have a good piece of wood but sucks if you have to chainsaw it up because a 20 or 30 ton log splitter won't break it. I've walked away from beautiful Red Fir trees for some thing like Alpine Fir because of the limbs where too thick and knew my splitter would never break it. There is other factors I look at too like debris amount each has. It's nice to have a good piece of wood but I hate to have to rake up tons of barks and wood debris to have to burn it off or haul it off. I to be shedding debris the whole trip from forest, splitting area, wood shed, to the house and have to clean up after it every step.
Yes Sir... Ready to be burned as soon as it split. Not really typically get most of my wood in spring and let it sit all summer in the shed curing. Already got 7 cord in the shed now. Pine and Red Fir are close in the BTU numbers. Tamarack is actually better wood but hard to fine out here.
Nice. Red Fir is a good firewood. I just tend to lean away from using solely a primary fuel. Kind of like diesel engine with a huge set of injectors and small turbo. You get lots of smoke and lots of heat. So I tend to mix up with some lighter BTU firewood to offset the fuel amount. So I can easily start a morning fire and warm the house with some Alpine Fir or Spruce where it doesn't get too hot and require a choke down of the air of the stove. Just food for thought... I really do hate having to clean a chimney in December...
Strange bobbing of the fuel pressure gauge?
Here you go... http://www.cumminsforum.com/forum/98-5-02-powertrain/21962-cavitation-not-your-vp-44s-friend.html Sorry to say the video is long gone...
Same as the stock Carter lift pump which has the same problem for caviation because of recirculating fuel back to the inlet.
Geez! I thought it was a 1/2 ton!
Pull him over and make him unload the trailer on to vehicle/trailer that can properly haul the load. If the trailer is over gross weight limit he would be force to unload and reload to proper vehicle. Of course all the owner responsibility to pay all the fees and fines...
So... I have a bit of a project..
Time to look at the date code of the tires and replace any that are over 5 years old. Also did you check your air pressure before leaving? How fast where you traveling?
That's is the point the AirDog and FASS have a dedicated return line that returns the flow back to the tank. The Raptor on the other hand returns within the pump body. Raptors are prone to the caviation issues like the old stock Carter's because of the return within the body. If Raptor was a dedicated return pump then the problem most likely wouldn't exist. As for my volume numbers they are just roughly speaking.
Most of us don't even own a tachometer we just do it by ear. As for the grinder for $40 bucks that's rather cheap. As long as you only taking small bites at the chain shouldn't be any problem. Also the grinder is known for weak grinding motor but that's a good thing because it not strong enough to over heat the chain cutter and take the temper out of the metal. Just sharpens.
Rather good with tuning saws and sharpening chains. A matter of fact this same friend this morning sharpen both saws for me on his little Harbor Freight Chain Sharpener. Works really good and does a excellent job of re-tuning a well worn chain back to specs again. http://www.harborfreight.com/electric-chain-saw-sharpener-68221-8346.html As for tuning the carburetor on a chainsaw you have to be careful with the mixtures screws. L mixture screw you want to set it so it idles smoothly. H mixture screw you want to be on the rich side. If its too lean it will starve the engine for lube oil and over heat it rapidly. This is hard to explain in words on how its suppose to sound as you start from over rich working back lean there a particular sound of blubbering you'll hear then light fade it back. But don't go for absolute perfect smooth once again it will be most likely to lean.
Well back at it again. Buddy down the road called me this morning and wanted to haul firewood. I was considering just buying a few cords but being the waiting list is too long. I'll just hop out and get a load. So hook up with him this morning...
For AirDog or FASS with 3 lines. The return line is the remaining fuel flow back to the tank so if your injecting 2.5 GPH the other 147.5 is flow back on the return lines (injection pump and fuel pump). Now Raptor and other like pumps with 2 lines (no return line) now those return the fuel internally. So again a 150 GPH pump will return the same 147.5 GPH internally and the return line of the VP44. This is where cavitation is possible.
I wonder what Idaho DOT officer would do... I'm pretty sure he's over weight for sure.
Shopping for a Daily Driver
Did you look at the all wheel drive thing for the winter time travel?
Cleaning Pine Sap off painted surfaces
I've been doing that for a very long time. Just come in from splitting wood or cutting wood and have sap on my hands. No problem just grab the rubbing alcohol and rub my hands together and then wash then with soap and water afterwards. Got sap on your seats? No problem I used the rubbing alcohol to remove it from fabric or clothing as well.
